cut off switch question...
Anything electric, AC or DC
Postby Dale M. » Mon Nov 23, 2009 10:56 am
As for "normal" light switches.... Most DO NOT have a DC "rating" on them only a AC rating, that has to tell you something.....
I personally like the DC "Master Disconnect" switch for automotive/boat application.... Contacts in switch are rated something like 100 AMPS, that means it will cycle on/off about a jillion times with out wearing out....
Dale
Dale M.
Images: 18
Postby planovet » Mon Nov 23, 2009 11:50 am
Just giving you a hard time Doug :)
ImageMark (& Cindi)
planovet
The Cat Man
Postby doug hodder » Mon Nov 23, 2009 11:52 am
Sorry Mark....I dumped it before you posted. I hadn't used a switch like Jack suggested didn't know they had them as inexpensive as that. Doug
Postby caseydog » Mon Nov 23, 2009 12:03 pm
doug hodder wrote:So....do you all have on board extinguishing systems as well? :lol: Doug
If you are going to race it, it has to have that, too. Both the kill switch and the fire system have to be accessible by safety crews on the outside of the car.
In addition, the driver can also activate the fire system.
If you put the kill switch in the cockpit, or under the hood, you need to run a cable from the hole in the paddle to the outside with a pull handle.
The lightning bolt indicates the kill switch, and the "E" is to set off the fire system.
My build journal is HERE
caseydog
Images: 515
Postby planovet » Mon Nov 23, 2009 12:25 pm
ImageMark (& Cindi)
planovet
The Cat Man
Postby caseydog » Mon Nov 23, 2009 1:08 pm
Looks like Mark got into the catnip, again. :roll:
CD
caseydog
Images: 515
Postby Arne » Mon Nov 23, 2009 1:14 pm
Dale M. wrote:As for "normal" light switches.... Most DO NOT have a DC "rating" on them only a AC rating, that has to tell you something.....
Dale
They do not have a dc rating because they are made for 115v a/c.... I use them in my tears with no problems.
The recommendation is that you cut the watts in half when using for 12v. That leaves you with 72 amps with 12v... since I use a 30 amp fuse, I am not concerned.
www.freewebs.com/aero-1
Arne
Mr. Subject Line
Images: 96
Postby caseydog » Mon Nov 23, 2009 6:07 pm
My thinking -- call me crazy -- is to pay seven bucks for the switch they use on race cars. Yeah, it's seven big ones, instead of a buck-fifty, but that's how I roll.
CD
caseydog
Images: 515
Postby satch » Mon Nov 23, 2009 8:02 pm
caseydog wrote:Looks like Mark got into the catnip, again. :roll:
CD
:lol:
Doug, HF has them for under $5, not sure if you would want HF. I picked one up for my boat at Kragens, I think it was around $10.
If it itches. scratch it
Rick
satch
Images: 63
Postby Joanne » Mon Nov 23, 2009 10:24 pm
Doug,
Couldn't ya just strip the wires back and twist them together? You could pull 'em apart when you didn't want'm hooked together.... :lol:
Sure look'n forward to seeing your next trailer!
Joanne
New! My Camp Cooking Forum
Project Desert Dawg website
Universal Health Care
Joanne
Queen of Cast Iron
Postby doug hodder » Tue Nov 24, 2009 12:18 am
Hey Joanne....the light switch was a step up for me. I usually just disconnect the hot wire...guess I could still do that, it's always worked. Doug
Postby Joe G » Tue Nov 24, 2009 2:41 am
I've been eyeballing this one:
$ 6.37 HD push-pull switch rated at 75 amps, made by a reputable mfr (Cole-Hersee)
I like this style because it is more compact than the big plastic ones and has a similar continuous use rating (75A vs 100A). Plus it has sort of a vintage look to it.
Joe G
Images: 25
Postby Larwyn » Tue Nov 24, 2009 7:16 am
doug hodder wrote:Hey Joanne....the light switch was a step up for me. I usually just disconnect the hot wire...guess I could still do that, it's always worked. Doug
That's actually my choice. One case where I prefer to keep it simple.
Larwyn
Larwyn
Mad Kilted Texan
Images: 210
Postby Juneaudave » Tue Nov 24, 2009 9:33 am
I've just got to ask (because I didn't add a master switch and now I feel insecure :baby: )
I guess I thought you put a master switch in to prevent drawdown during long term storage...and if that were the case...am I goofing up? I put in a three stage charger with the intent to just leave it plugged in and fully charged during non-use. Is there a reason you want to disconnect the battery for towing?
I'm so confused :oops:
Juneaudave
Images: 380
Postby alffink » Tue Nov 24, 2009 10:08 am
I went with a classic blade or knife switch, a bit pricy and it was probably over-kill, but it works for me and oh so positive and simple to boot.
http://www.mcmaster.com/#7110k23/=4n5fvi
and just a glance you know your dis-connected.
alffink
Images: 37
Return to Electrical Secrets
