Hi,
Somewhat new here. Been doing a lot of reading. I'm about to start my project of a teardrop using a HF 4X8 trailer.
However, can't find wat I need to know.
----The trailer measures 49" wide. If the top (skin) is 1/8" plywood, I need the 'body' to be exactally 48". Obviously the sidewalls should be on the outside of the deck(floor) and not set ON the deck, so therefore I'll cut the deck to 46 1/2" (using 3/4" sidewalls).
The Benroy plans say the sidewall should overhang the trailer frame. Is that necessary? Do I need to make the trailer frame narrower?
