Found a New Tool for Cutting Aluminum
Postby John6012 » Thu Nov 03, 2005 4:44 pm
I don't know if anyone has used a Rotozip before to cut aluminum, but it works great! Only thing, is to go clockwise otherwise it will jump around and tear up your aluminum. It's fast, and fewer chips - or at least smaller than a router.
John6012
Postby TonyCooper » Thu Nov 03, 2005 4:55 pm
I used it extensively on my teardrop. In fact I cut through two sheets of .030" aluminum sandwiched in between the two 3/8" thick 4' x 8' sheets of plywood.
When cutting aluminum, I found that if you spray a little light weight oil on the path to be cut, the blade will not clog up and it cuts like butter.
I used it with a router edge bit to cut the fan hatch in the ceiling, the formica on the counter top, as well as the aluminum skin for the doors. Simply lay the aluminum over the door and clamp together, then follow the door for a perfect cut....window cutout too!
I like my rotorzip! :thumbsup:
I caught it on sale at HD for $69. Regularly $149. I want the jigsaw handle now.
My Tear Build Site
"No comment"
TonyCooper
Official Pot Stirrer
Images: 35
Postby John6012 » Thu Nov 03, 2005 5:30 pm
Glad to see others use the Rotozip. I was building a cottage and needed one and bought one off Ebay for $11.00 case included.
John6012
Postby Classic Finn » Fri Nov 04, 2005 6:19 pm
I was wondering if any of you could post a photo of the Rotozip so I would know what it looks like - sounds like a great way to go...
Maybe I can find one of them here in reindeerland... :D
All our best to you.. :thumbsup:
Classic Finn
Classic Finn
Midnight Sun Voyager
Images: 146
Postby madjack » Fri Nov 04, 2005 7:10 pm
Heikki... here is a linky...not sure how to descibe...do y'all have Dremell tools over their or maybe something known as a rotary carver...any way it is something like a router that uses a specialty "spiral" or rotary bit...this bit cuts from the side and can be used similarly to a plnuge router...due to the length of the bit, it can cut deeper than a regular router bit...there are many specialty attachments and bits and burs for all manner of jobs
madjack 8)
Postby Hardin Valley Magic » Fri Nov 04, 2005 7:15 pm
Great tool however, when cutting anything over 1/2" be VERY SLOW I learned the hard way and the bits (for really good ones) are a little pricey.
aka Steven D.
Hardin Valley Magic
Postby Classic Finn » Sat Nov 05, 2005 7:15 am
Thank You
Yes we have tools by Dremel for sure.. I may know of who sells them now that I know what it looks like... thanks..
Does Dremel have a similar Tool? Or Bit?
Classic Finn
Classic Finn
Images: 146
Postby madjack » Sat Nov 05, 2005 7:33 am
Heikki, the dremel and the rotozip are the same type of tool except the rotozip is several times larger and more powerful...kinda like an industrial version of the dremel or more in line with a slim line router...I don't believe there is any interchangeability between their respective bits...however they do have bits that do similar things/jobs
madjack 8)
Postby Classic Finn » Sat Nov 05, 2005 1:00 pm
Madjack - Guess Im going out monday to buy my Christmas Present
a Little Early....Also a big thanks to the other gentleman for telling us about this...
:twisted: 8)
Classic Finn :thumbsup:
Classic Finn
Images: 146
