after looking for a trailer to buy and covert in the UK, it looks like the best way is to build my own
the plan is for a 6ft 6 " X 4ft teardrop style, lightweight is the key here, must be as light as possible
loads of options, i was going to go with the A frame style, but as i want the cabin to be light, i was going to build it out of 12mm ply, i would worry that the sides would flop over the pointy bit of the A
so then came the square frame work, its not going to be that much heavier, we are only talking 1 more 4ft length
so then comes the tongue, after reading the guide, i still cannot work out thats the strongest /? ? /
then its the section to use, so whats better, L or box section ? ? ? ?
2 " big enough ? ? ? ?
if i used ali it would be rust proof, then again i could just hammerite ( or POR 15 ) some mild steel
any feedback advise
thanks
matt
