Ultra light chassis
Ultra light chassis
Postby newbuilder » Sun Jan 17, 2010 12:59 am
Does anyone have any experience with the chassis design in the design library? Why could I not use a sprung axle with it?
Beat it to fit, Paint it to match!
newbuilder
Re: Ultra light chassis
Postby angib » Sun Jan 17, 2010 7:35 am
newbuilder wrote:Why could I not use a sprung axle with it?
The Ultralight uses the strength of the rubber torsion axle as part of its structure. If you wanted to use a leaf-spring axle, then you have to replace that strength. You would need to lengthen the angles on the side so that they pick up the two ends of each spring and then you would need to add a cross member at each end to hold the axle brackets rigidly in place.
This would add quite a bit of extra weight and complexity to the chassis, so I never considered that alternative - it kinda stops being an ultralight and becomes a light-ish.
Andrew
angib
5000 Club
5000 Club
Images: 231
Postby newbuilder » Mon Jan 18, 2010 12:09 am
So how does the torsion axle compare to a spring axle in price?
newbuilder
Postby aggie79 » Tue Jan 19, 2010 9:26 am
My #9 Dexter torsion axle was about $230, including the weld-on mounting brackets. The hubs are the standard lube hubs, and I did not get brakes.
The #8 Dexter is lighter and less expensive. (I went with the #9 to get the larger bolt pattern on the hubs so I could use car wheels.)
Postby dwgriff1 » Tue Jan 19, 2010 11:35 am
I used a Dexter 8 and the price was under $200, but that was a few years ago.
dave
dwgriff1
