Nosty wrote:I may be wrong, but I'd be a little leery of using florescents. Just by their nature, they can easily fall out during travel and break, leaving those fine glass shards and toxic powder all over an area where you'll probably be preparing food. I'm sure a lot of people have used them successfully, but I'd consider the pot holes and rough roads and the way fluorescent tubes mount into the fixtures. Just my opinion.
planovet wrote:Well, the light I used (and linked to above) is sold for RVs. It also has a plastic cover that prevents a bulb from falling if it did fall out of the fixture. I've been over some pretty bumpy roads and it has performed well. I guess it just depends on what you want and like.
Aaron Coffee wrote:If florescent bulbs break the glass shards will cut right through you, at least thats what my fifth grade teacher used to tell us when we would play ball in the classroom when it was to cold to go outside for recess.
