LED Utility Light
Anything electric, AC or DC
LED Utility Light
Postby bdosborn » Mon Jan 25, 2010 2:38 pm
After browsing Chorizon's Hill-Country Hauler Build I noticed he had a picture of wlooper89s tongue box with a light in it, which I thought was a pretty good idea.
I'd decided that all my lights in this trailer would be LED so I came up with an easy LED utility light.
I started with a cheap LED strip I got from eBay ($5.99 including shipping) and a piece of wood with a 1/4" dado in it.
I attached it under the lid. The LEDs are held in by friction only (no glue) so I can swap them out if the burn out.
I needed a switch so I tucked one away in the corner. I still need to add some kind of cover over the wires and terminal strip:
The LEDs are too blue for my taste to read by (so I wouldn't use them inside the trailer) but they work for a utility light. They don't use much juice and they're waterproof :
Then I realized I needed a light for the generator control panel so I added a little surface mount LED powered by the same switch:
Images: 806
Postby mwallace61 » Mon Jan 25, 2010 7:52 pm
slick. Looks good....
mwallace61
Postby Miriam C. » Mon Jan 25, 2010 8:01 pm
:applause: :thumbsup: You always do the neatest stuff......
Postby bdosborn » Tue Jan 26, 2010 9:14 pm
Miriam C. wrote::applause: :thumbsup: You always do the neatest stuff......
Thanks Aunti!
Images: 806
Postby mikeschn » Tue Jan 26, 2010 9:15 pm
I'm jealous...
Would you design an O.W.W. for me, with all the fixings? ;)
Postby bdosborn » Tue Jan 26, 2010 9:22 pm
mikeschn wrote:I'm jealous...
Sure! But I figure I've got another couple of years messing around with this one before I could get to it... :lol:
Images: 806
Postby mikeschn » Tue Jan 26, 2010 9:32 pm
:lol: :lol: :lol:
Postby TENNJIM » Wed Jan 27, 2010 2:10 pm
Both are great installs. Not as good, but a Puck Lite mounted underneath the lid will work. I got the kind that rotates and tilts and can focus it on my hitch when needed. The drawback is replacing batteries, but they last reasonably well. The Puck-Lite came three to a package. I put one high on each sidewall to add lighting on back shelves. Almost never figured out where to put the third one; and then the tongue box came to mind. The adhesive has held it okay when traveling. It is a push-turnon; so clearance directly underneath is needed when the lid is closed.
8)
Jim B / Utah
TENNJIM
Palladium Donating Member
Images: 35
Return to Electrical Secrets
