Thank you everyone for your replies and good info on the galvanizing issue.
I came back yesterday from a company that has been making utility trailers for over 30 years plus.
I spoke with the company director for over 2 hours about different things concerning trailers and teardrop trailers and about my friends here on the famous T&TTT. I also showed him the website and the magnificent builds. He was quite interested
Well anyway. He told me this. Galvanizing is best for protection of the frame or any other item that he builds especially in our quickly changing climate and geographical location. The entire frame is dipped into a tank. Not just sprayed on.
Some holes may need to be drilled into the frame if its steel that is not U shaped or one that cannot be accessed by the galvanizing.
Now this is interesting to me however also logical. Galvanized steel can be powder painted however a lite sanding or beadblasting or equivalent can be done in order to have the powder coat stick. Not removing the coating of galvanizing.
On powder coating only, the frame intends to start rusting from the inside out. Causing damage that cannot be seen and at times too late to repair when noticed.
So this is what will be done to our tear frame. Dipped in galvanizing tank and lightly scuffed or so called sanded. Then painted by powder coating.
The company also has a newly built yacht trailer that this procedure has undergone.
Also he stated that the best way to do this is let the galvanized trailer frame sit outside in the elements for a longer period of time and then do the scuffing of the steel and then proceed to powder coat.
Another learning session in my ol age.
