I like Andrews new frame design so much
, I asked him to redraw it for my 5'X8' modified Ultralight build (500-600#). Andrew redrew it for the Ultralight profile and I think it's the perfect frame design for any light weight build. The main triangle is 1" x 2" 11ga. rect. steel tubing. It uses less than 20' of this tubing, so one length is all I need to buy. The the rest of the steel is short pieces I can get from scraps.
Andrew drew it with 8" wheels, but I will use 12" I know the 550# stub axles will present a challenge, but I am committed to building this design as drawn. It will be the foundation of my light as possible Tear. I will document the process if others want to use this frame design.
Andrew.. Thank you for the new 5x8 Pico frame.
BTW/ being new to using the forum, where should I start posting pictures and my build thread? Should it be a whole new thread(where) or in the Ultralight thread? I will need some help/suggestions during my build.
Larry C.
