"Room for Two" (Chambre pour deux)
Postby BrianStaceyErnst » Tue Dec 29, 2009 9:09 am
The Build Looks Fantastic Mike!... don't get a chance to get over here all that often but I do from time to time. Looks AWESOME!
Brian Ernst - TEARJERKERS Administrator
BrianStaceyErnst
Postby Cliffmeister2000 » Tue Feb 23, 2010 12:34 pm
Hey, mike! It's been 2 months since your last update! I'm going through withdrawls here! :(
God Bless
Cliff
♥God. ♥People.
1 John 4:9-11
My Teardrop build pictures
Cliffmeister2000
Titanium Donating Member
Images: 157
Postby Mike_La » Sun Feb 28, 2010 9:37 pm
Sorry 'bout the withdrawls, Cliff. :R
As a matter of fact, I did work a bit on it today. The weather was Spring-Like , so I pulled the TD out of the shop into the warm sun light. It did make it to 65°.
I cut the streetside door opening.
Then I commenced to cutting the window opening in the doors. Made a slight boo-boo, but it won't show with the window in place.
This is the window I'm installing in the doors.
Here's a window installed in one of the doors.
Gonna pick up a couple of 4X10 Aluminum panels for the skin this week.
Mike
"Believe you can and you're halfway there."
Theodore Roosevelt
Mike_La
Images: 71
Postby Shadow Catcher » Sun Feb 28, 2010 10:37 pm
Looks great and it is good to see the process.
Postby Mike_La » Tue Mar 02, 2010 6:43 pm
I temporarily installed the doors for a test fit. If you'll notice, these doors are fitted with Hurricane Hinges
First chance I get, I'll cut out the profile in the aluminum skin and lay it in place. For now, my plan is to let the skin float on the plywood sides, being retained only by the edge molding and doors.
Of course, I'll apply the epoxy seal to the plywood sides, then after it dries, attach the skin.
Mike
Theodore Roosevelt
Mike_La
Images: 71
Postby John T. Hodgen » Tue Mar 02, 2010 9:40 pm
Hey Mike,
Seeing the sun in your pics reminds me that spring will be here soon, I'm wishing this 18in. of snow that we have up here would melt. Back to your build, its looking great! I wonder...do those windows open any? I do like the look and the doors too, wish I had the money for those that you had up for sale....Kool! Your coming along and doing well. Take care--
Til later by the fire--John T. & Linda 8)
John T. Hodgen
Postby Juneaudave » Tue Mar 02, 2010 9:46 pm
Lookin good!!! Those doors are going to turn out nice!! :thumbsup:
Juneaudave
Images: 380
Postby Mike_La » Tue Mar 02, 2010 9:56 pm
John,
The windows do open. Actually, they slide up to open and have three opening hights. They're travel trailer windows I bought used on Ebay.
BTW, I still have a couple sets of these door in the For Sale section.
Mike
Theodore Roosevelt
Mike_La
Images: 71
Postby Mike_La » Tue Mar 02, 2010 9:57 pm
Juneaudave wrote:Lookin good!!! Those doors are going to turn out nice!! :thumbsup:
Thanks, Juneaudave.
Mike
Theodore Roosevelt
Mike_La
Images: 71
Postby 2bits » Fri Mar 05, 2010 11:27 pm
I was wondering how the windows mounted up. Caseydog showed me how his were done and I wanted to see if your's were the same way. Basically, you slip on the trim ring and then use a self tapping sheet metal screw to make it's own hole in the window to screw in to. Does that sound about right? Thanks, I am thinking I might be able to yank out my moon roof and reinstall it with no sealant showing if this is true...
Thomas
2bits
2bit Member
Postby Mike_La » Sat Mar 06, 2010 12:12 am
i don' t entiende, porqué don' t usted quiere el sellante ?
Mike
Theodore Roosevelt
Mike_La
Images: 71
Postby Cliffmeister2000 » Sun Mar 07, 2010 1:44 pm
Etech wrote:If you'll notice, these doors are fitted with Hurricane Hinges
Just curious, what keeps the door from sliding off when fully open? My hurricane hinge doesn't have any stop for sliding the hinge apart.
God Bless
Cliff
♥God. ♥People.
1 John 4:9-11
Cliffmeister2000
Images: 157
Postby aggie79 » Sun Mar 07, 2010 1:51 pm
Mike - Those doors are looking great! Actually, your whole teardrop is looking great. Keep up the good work.
Postby Mike_La » Sun Mar 07, 2010 7:36 pm
There is a stop, top & bottom.
The doors I'm using on my build are to only pair with Hurricane Hinges. All of the others I'm selling have Piano Hinges.
Mike
Theodore Roosevelt
Mike_La
Images: 71
Postby Mike_La » Sun Mar 07, 2010 7:48 pm
aggie79 wrote:Mike - Those doors are looking great! Actually, your whole teardrop is looking great. Keep up the good work.
Thanks, Tom.
I cut out and did a test fit on one of side panels today(thanks to everyone who replied to my question about how to cut the aluminum profile).
For the newbies, the sides are White. The protective plastic film is Blue. I'll remove the Blue film after the TD build is a little more advanced.
BTW, Your build is coming along nicely also. At least you're working on the galley hatch. I'm dreading that part.
I'm trying to get as much done as possible for the Cabela's Event(two weeks away). I'll place a sign on it, "Under Construction".
Mike
Theodore Roosevelt
Mike_La
Images: 71
