12 ft Winter Warrior build
Postby aggie79 » Fri Mar 05, 2010 12:49 pm
RAYVILLIAN wrote:aggie79
I hope to get him done about the middle of the summer so yep he'll be at LCG 5
Gary
Sweet! :thumbsup:
Postby starleen2 » Fri Mar 05, 2010 6:23 pm
RAYVILLIAN wrote:Starleen
Yep the box is part of the front of the trailer so there will be another hinge there but I have an idea on how to keep the water out. If it works out I'll have a gutter like what is on the trunk of a car under the roof door so any water that gets in will run back out. But I'm not exactly sure how I'm going to do it yet.
Gary
Maybe something like this:
starleen2
5th Teardrop Club
Postby RAYVILLIAN » Fri Mar 05, 2010 10:18 pm
Sorta What I'm sorta seeing in my head has the hatch door going down over the front edge of the box with a gutter like that all the way around the way that car trunk lid do. I'm just not sure if I'm going to use aluminum channel like what your showing or do it with fiberglass,
Gary
111961Image
RAYVILLIAN
Images: 109
Postby aggie79 » Fri Mar 05, 2010 10:28 pm
Gary
Did you see how Ed is doing his gutter on his "The White Pearl" build (page 1)?
Postby RAYVILLIAN » Sat Mar 06, 2010 9:40 am
Aggie I was just looking at that after I posted last night. I think I had seen it before that's why it's been bonseing around in the back of my head.
I've got a few other problems to solve before I get there though so it's on the back burner right now.
Gary
111961Image
RAYVILLIAN
Images: 109
Postby starleen2 » Sat Mar 06, 2010 11:40 am
Gary - got any dimensions for us yet? like what is the height of the sleeping quarters before the hatch? :thinking: Just another thought - I didn't see any pas through to the storage box on the front bulkhead - that prompted the first question about the second waterproof hinge ;). Also are you gonna incorporate some kind of lift mechanism?
starleen2
5th Teardrop Club
Postby RAYVILLIAN » Sat Mar 06, 2010 2:22 pm
Starleen
He's 6' wide and 12' long and 5' high inside at the hinge point. the height is the same as the old one. We're putting in a 54" wide bed which will give us 9" on both sides of the bed to be able to slide back to the galley area. Putting in a 3" drop floor in the center of the galley and the back seat at the table contains the porta pot and the seat will raise and the front drop so it can be used with out dragging it out. The back seat will lift out to make access to the bed area in my side.
The only hole in the front wall is for the AC. I'm not sure what else will go in there. I was thinking about putting the battery in there but I"ve about decided to put it under the bed over the axle to cut down on tongue weight.
The front cargo doors are to a under bed storage that goes all the way through and I'm hoping to make the doors big enough to be able to put an easy-up in there. The rest of the under bed storage I can get to through the side doors. that's actually the main reason that I'm putting them in. This will be the first side doors I've done so I've got the usual worries about leaks there.
Now in normal Teardrop style I've given you more information than you really wanted to know. :lol:
GAry
111961Image
RAYVILLIAN
Images: 109
Postby WarPony » Sat Mar 06, 2010 3:15 pm
RAYVILLIAN wrote: We're putting in a 54" wide bed which will give us 9" on both sides of the bed to be able to slide back to the galley area...
Gary, did you type that right? 9 inches sound a little tight.
Jeff
WarPony
Images: 289
Postby RAYVILLIAN » Sat Mar 06, 2010 3:46 pm
Yep Jeff that's right and it is tight but it's just someplace to put your feet while you scoot down the bed to get in to the galley at night or in bad weather. I didn't want to make the trailer any wider and the only way to get more room was to go to a 48" custom made bed. We couldn't stand very well in 5' anyway. We also have the option of going out the side doors if the weather is good and 9" gives a little room to put your shoes on in side.
Gary
111961Image
RAYVILLIAN
Images: 109
Postby WarPony » Sat Mar 06, 2010 4:00 pm
Okay, okay....... I see now. I had to go back and look at your pics a little closer. I thought you meant you had a 9" gap in the bulkhead to get through to ENTER the galley. Now THAT would've been tight........ yikes!!
Jeff
WarPony
Images: 289
Postby RAYVILLIAN » Thu Mar 11, 2010 7:43 pm
Well I picked up the frame this morning. This is going to be interesting the the frame takes up most of the shop. Boy 12' is long. I had to pull it back to the shop by hand through 50 yds of squishy mud. :cry:
Gary
111961Image
RAYVILLIAN
Images: 109
Postby Miriam C. » Thu Mar 11, 2010 9:39 pm
:thumbsup: :applause: And a beautiful frame it is! Looking forward to watching this one. :thumbsup:
Postby starleen2 » Thu Mar 11, 2010 9:40 pm
HA - now I can find where you live Gary! - I'll just look down from the google satellite view for your city and find the only workshop with a 12 ft long trailer sticking out the end! - Really - that's a good looking start you got!
starleen2
5th Teardrop Club
Postby RAYVILLIAN » Fri Mar 12, 2010 7:59 am
Actually Starleen the google map is at least a year old. I've been trying to see a $2 million house that was built back in the woods a mile north of us and there is always a convenient cloud over it, but the bakery/winery where I make pizza Friday night has had a patio cover on it for over a year and it isn't there yet. If you find my house though the white blob on the southeast corner is the old Winter Warrior.
GAry
111961Image
RAYVILLIAN
Images: 109
Postby Rigsby » Fri Mar 12, 2010 11:50 am
This is gunna be one fun build. keep us updated with plenty of pics
DOOIN IT THE YAARKSHA WAY--FA NOWT, THA NUS !!
Rigsby
Users browsing this forum: Bing [Bot] and 5 guests
