Vintage Tripper Tear Drop rebuild-Update 3-24-2011
Postby aggie79 » Sat Mar 20, 2010 11:53 am
txturbo wrote:
aggie79 wrote:Mike,
I hope you don't mind me posting your image.
It will be a lot of work, but when you are done you will have a very unique teardrop that has really nice lines.
No problem...but my name is Dan :)
Sorry about the incorrect name, Dan.
Not sure where the "Mike" came from. I must have typed this after applying some epoxy. I really like your teardrop - the profile, the siding, etc., and will be following your build closely.
I believe the fenders you are looking for are the cub/mod/ken-skill type fender. I'm using the 11" wide ones on my build. This is where I bought mine (and also my trim, windows, hatch hinge, seals, etc.): http://www.lilbear.teardrops.net/parts3.html#fenders
Postby txturbo » Sat Mar 20, 2010 1:33 pm
Thats the ones! But....I don't like them that much. $500 for a pair of fenders just doesn't make sense right now. I could buy a pair of steel 40s era car fenders for that. I'll either go back with the same kind of fenders that were on it or maybe build something from scratch.
txturbo
Postby txturbo » Sun Mar 21, 2010 2:10 pm
Found some chrome wheels with tires at a swap meet today. All I need to complete the frame is a set of fenders. Who said this looked like a weekend rebuild? :roll:
txturbo
Postby parnold » Sun Mar 21, 2010 5:46 pm
Great looking wheels!
parnold
Images: 302
Postby txturbo » Sun Mar 21, 2010 6:25 pm
Thanks...now they just need some baby moons.
txturbo
Postby txturbo » Mon Mar 22, 2010 1:09 pm
Bought the plywood this morning. Change in plans as of today. I'm going to build the shell, spray the whole outside with ceramic insulation to seal and insulate it, then mount it on the frame. That way I can be sure its water tight. So, the second thing on my "to do" list today is to go buy a tarp. Cuz I know for sure it will rain once I start to assemble the shell. My plan is to raise my out door 4-post car lift all the way up and drape a tarp over it. Then I'm off to find some peel and stick vinyl floor tile to cover the floor with before I add the walls.
txturbo
Postby John T. Hodgen » Mon Mar 22, 2010 1:30 pm
sounds like a PLAN!!! Looking good too.
Til later by the fire--John T. & Linda 8)
John T. Hodgen
Postby txturbo » Mon Mar 22, 2010 5:43 pm
Got my covered area setup. Also got the vinyl tiles put on the floor.
txturbo
Postby txturbo » Tue Mar 23, 2010 6:35 am
Here's a pic.
txturbo
Postby txturbo » Fri Mar 26, 2010 6:39 am
Haven't done much on the TD the past couple of days. My back is giving me trouble. Lifted and moved to many sheets of 3/4" plywood. I do need to go get one more sheet though. Weather was postcard perfect yesterday for working on it, but I could barely move around. Not to bad today. Waiting for some help to show up to move the sides into position so I can do some more work on them.
txturbo
Postby txturbo » Sat Mar 27, 2010 6:48 pm
Got a little done today. I drilled all the holes for the dowels in the floor and walls and cut the spreaders for the roof. Maybe tomorrow evening I can start to do some assembly.
txturbo
Postby txturbo » Mon Mar 29, 2010 5:54 am
Help is arriving tomorrow morning to help with assembly. Todays "to do" list is to grab another sheet of plywood and pick up the 2 gallons of ceramic insulation that I will use to spray over the assembled shell.
txturbo
Postby txturbo » Tue Mar 30, 2010 4:01 pm
Got the sides glued and screwed on today. Here is a pic with one side held in place.
and one of the floor in place on the frame.
txturbo
Postby John T. Hodgen » Tue Mar 30, 2010 4:25 pm
hey TxTurbo,
Looking good and glad to see you have help now. Hope everything is doing good. I priced that ceramic insulation on a website--$159 for 2 gal. Did you get it cheaper than that? Watching with joy.
John T. Hodgen
Postby txturbo » Tue Mar 30, 2010 5:48 pm
John T. Hodgen wrote:hey TxTurbo,
Thanks John.....actually I did. Since I was a return customer and I drove over there to pick it up he gave me the Jobber price. Saved me about $25. He also gave me a cap and shirt. When I told him what I was using it on he said he wants to come by and check it out and maybe he can get me some press time. Also told me they now have a new hybrid product that combines the sound deadening and insulation properties. I need to inquire more about that.
txturbo
