Chris D wrote:Hows about some heat? Heat carefully and a good sharp scraper?
Just a thought. Do you SEE the caulk when you install the window?
Chris D
Chris D wrote:Will it effect putting in the window or sealing the window? If not why not just leave it alone?
Chris D
Chris D wrote:I dont know if I would trust new over old. Is the window a clamp ring design and has a rubber seal on the out side?
Chris D
Then, the Walmart guy said he thought "Goop-Off" would work better than either the Acetone or the Lacquer Thinner.
S. Heisley wrote:Alfred wrote:Then, the Walmart guy said he thought "Goop-Off" would work better than either the Acetone or the Lacquer Thinner.
....It's "Goof Off" and yes, it does work better than the other two mentioned.
Users browsing this forum: Bing [Bot], Google [Bot] and 2 guests
