At this price it would be like you having me build you a custom trailer for $500.00 bucks. How can you pass that up?
I have for sale a 2009 custom made Woodie trailer.
It has;
A two burner stove with a 11lb LP fuel tank.
Sink with a 2 1/2gal under the cabinet water supply and an under the trailer waist line.
Power is supplied by 12v only with two lights and a 12v outlet inside the trailer and a two stage light in the galley. The battery is stored in the center cabinet of the slide out.
The bed is a 4" queen size mattress split down the middle. With zippered removable custom made covers.
The trailer has stabilizer jacks on all four corners.
Matching full size spare tire mounted under the trailer.
The trailer weights in at 1400lb with a tongue weight of 210lb.
The frame is welded up 2"x2"x3/16 angel Iron with a 2 1/2"x 2 1/2" tongue. The coupler is 2".
The axle is a 2000lb flexiride torsion axle.
The dimensions are=
Outside
Width- 7' from tire to tire.
Height- 70 1/2" from ground to top of vent.
Length- 14' 10" can be shortened a little bit.
Inside 58" x 79 1/2"
The frame of the trailer was registered in 2007 and the body and trailer was finished 2009.
More photographs of this trailer can be viewed in my album. Which will show you some of the building processes.
If you have any questions at all feel free to e-mail me at [email protected] I will be more than happy to answer them.
There is a new price on this trailer. The price is $6500.00 And I'll throw in the car cover for free.
Once again if you have any questions don't be afraid to ask. Thanks - Wayne Reynolds
