by doug hodder » Mon Jan 25, 2010 1:37 am
There are extrusions that can be attached to the trailer side that will allow you to attach a side table. I typically attach receivers under the frame that will allow it to be attached to either side depending on how I set up. It's just 1" sq. tube with a slip in piece, however it does require a frame for the table. It is a welded up item. The advantage is that nothing is attached to the side of the trailer, can be located on either side, and be installed in a high/ low elevation or at 90 degree angles. The down side....it's not super stable, can't sit on it, does have some movement, but can support a coleman stove and a waffle iron, that may or may not be important to you. Doug
