Honda Generator
Postby Guest » Fri Nov 25, 2005 3:13 pm
Gage wrote:But who needs elec coffee :QM :?
I only need electricity to grind the beans.
Used a sock and a hammer once, when I left the grinder at home. :lol:
Guest
Postby Chris C » Fri Nov 25, 2005 3:28 pm
Dang Dean.......................was that sock clean? :? :laughter:
Chris :D
Chris C
Postby Guest » Fri Nov 25, 2005 3:35 pm
Of course it was...
I wasn't jonesing THAT bad. :lol:
BTW-The French press trapped all the little white fuzzies too.
Wasn't bad coffee... Worked for me.
I'd be willing to bet that I'm not the only member here to ever resort to doing that. :thinking:
Guest
Postby Chris C » Fri Nov 25, 2005 5:02 pm
You Win!!!!! :lol:
Chris :D
Chris C
Postby Arne » Fri Nov 25, 2005 7:29 pm
Dean, use a mortar and pestal.... you don't need no stinkin electricity...
www.freewebs.com/aero-1
Arne
Mr. Subject Line
Images: 96
Postby dhazard » Sat Nov 26, 2005 12:08 am
I found a trailer shop that uses a Kipor 2000 instead of an extension cord. They were nice and started for me, it was as quiet as the Honda but it smelled like a 2 cycle. I think for my money I will go for the Honda. Regards Dan
Many miles and many tears. Times were hard but now they're changing.
You should know that I'm not afraid.
dhazard
Images: 122
Postby madjack » Sat Nov 26, 2005 1:19 am
DHAZARD wrote:I found a trailer shop that uses a Kipor 2000 instead of an extension cord. They were nice and started for me, it was as quiet as the Honda but it smelled like a 2 cycle. I think for my money I will go for the Honda. Regards Dan
hmmmmmmmmmmmmm :thinking: don't know why it would smell like a 2 stroke since it is a 4 stroke engine...sure they didn't have 2 stroke bike running or were running some 2 stroke gas init....for the money I think I would buy 2 of the Mcculoghs instead of 1 Honda(actually I probably won't buy either)
madjack 8)
Postby dhazard » Sat Nov 26, 2005 12:31 pm
I asked if they were running it on mixed gas. His answer was no, it has always smelled like that and he added that it uses some oil. He didn’t know how many hr it had but thought that it was under 200hr. One of my other concerns is parts if / when something breaks. The Hondas have a good dealer network and parts shouldn’t be a problem with the Kipor or the McCuloghs that might be a big problem.
Regards Dan
dhazard
Images: 122
Postby purplepickup » Sat Nov 26, 2005 1:07 pm
DHAZARD wrote:I asked if they were running it on mixed gas. His answer was no, it has always smelled like that and he added that it uses some oil.
Regards Dan
Sometimes a smokey engine is the fault of the owner. A lot of people don't change oil in their utility gasoline engines very often and if they do, they don't necessarily use the correct oil for air cooled engines without filters. Those are two important factors that determine the type of oil needed. It pays to use something similar to the recommended oil...and do it often.
Another thing I like to do is change the original break-in oil after a few hours of useage. It's full of metallic particles that will wear the engine parts early if it isn't removed.
George
purplepickup
Postby madjack » Sat Nov 26, 2005 4:14 pm
Dan, you are right about the parts issue...of course if it is the Honda, by the time I should need parts I probably won't be getting out and about much anyway(so say these old bones)
madjack 8)
Postby doug hodder » Sat Nov 26, 2005 8:32 pm
Dean, is that what you did at the last Redwoods thing, or was it the first one....you were wandering around asking everyone if they had a bean grinder!....I didn't realize that you were that desperate!...Doug
Postby Guest » Sat Nov 26, 2005 9:50 pm
:shhh: There are people on this board who drank that coffee with me. :lol:
Guest
Postby doug hodder » Sat Nov 26, 2005 10:07 pm
So what you are telling me is that the dirty sock (my dogs toy) in the back of the truck was used for that? I thought you needed a rag for checking the oil in your truck!!!! :lol: Doug
Postby Kevin A » Sat Nov 26, 2005 10:18 pm
Hey Dean, you didn't use those coffee grounds for stop leak in your truck didya? :o :thinking: :worship: :lol:
Kevin A
The other guy
Images: 289
Postby doug hodder » Sat Nov 26, 2005 10:22 pm
Naaaa Kevin...he probably used them to quiet down the knocking on the rod...kinda like sawdusting a rearend.... :lol: :lol: doug
