Skeet'r II
Postby mikeschn » Thu May 07, 2009 7:30 pm
TheDuke wrote:Couldn't do it all those years ago, cuz I would have been fired, but it IS more fun, isn't it?
TheDuke
Yep!!! :D
Postby TheDuke » Thu May 07, 2009 8:04 pm
OK, here's the 5 O'clock, 7 May revision. The grille next to the taillights is for the PetCool, which is under one end of one of the kitchen counters.
TheDuke
Images: 68
Postby TheDuke » Thu May 07, 2009 8:06 pm
OK, why is the image not an image? it always worked before?
TheDuke
Images: 68
Postby Miriam C. » Thu May 07, 2009 10:28 pm
TheDuke wrote:OK, why is the image not an image? it always worked before?
There was a space between the img and the http. 8) No spaces allowed. Great plan! When will you start. 8) :thumbsup:
Postby TheDuke » Fri May 08, 2009 11:19 am
Miriam, like I told Mike, just as soon as I can get this other utility trailer repaired and out of the garage, I will start on frame assembly and the little bit of welding. After that it's sawdust time, but I'll have pics before that, hopefully.
BTW, awhile back, when you first saw this design, you suggested turning the bed 90 degrees. Well, it is. That's why it's wider. Both of us are altitude impaired, like Mike, so the width stayed within reason.
TheDuke
TheDuke
Images: 68
Postby TheDuke » Fri May 08, 2009 11:42 am
Shut my mouth, Miriam. You said "reverse" not 90 degrees. Now one person has to climb over the other to get to the loo, but I can still use the bed the other way, with just a simple revision of overhead cabs. Last minute thing.
TheDuke
TheDuke
Images: 68
Postby Miriam C. » Mon May 11, 2009 11:06 pm
TheDuke wrote:Shut my mouth, Miriam. You said "reverse" not 90 degrees. Now one person has to climb over the other to get to the loo, but I can still use the bed the other way, with just a simple revision of overhead cabs. Last minute thing.
TheDuke
8) Is there enough room for your heads and put the cabinets to the potty wall? MHO if you gain room then climbing over won't be so bad. If the inside person has extra foot room then all the better. Put the bed forward and gain lots of space. Cabinets can be night stands on either side. I am seriously thinking of putting a dresser in mine.
Something like this:
Postby TheDuke » Mon May 11, 2009 11:41 pm
Miriam
There is a revised floor plan that goes with the revised "trolley" outline I posted. It may answer some of your questions, but maybe it'll just create more! I'll see if I can get it posted tonight, otherwise tomorrow. Then you can have at it again!
I really appreciate your comments, as I know they come from experience, and mine just come come off the screen.
TheDuke
TheDuke
Images: 68
Postby TheDuke » Tue May 12, 2009 12:34 am
OK, here's the interior
TheDuke
Images: 68
Postby Miriam C. » Thu May 14, 2009 5:54 pm
:thinking: :twisted: I really like that. While my preference would be to have cabinets on the wall between the water closet and the bed you would loose a whole section. There is never enough. :thumbsup:
Postby TheDuke » Thu May 14, 2009 6:21 pm
Actually, there are some in that position, sort of, except they're the kitchen cabinets above the counter.
I had thought of making a small storage nook (maybe with a door) into the end of the counter right by the left persons pillow, maybe borrow 8" or so from the undercounter kitchen storage. the person on the other side of the bed doesn't have a problem.
TheDuke
TheDuke
Images: 68
Postby mikeschn » Fri May 15, 2009 5:00 pm
That's a nice change of direction. But I need to think about it some more...
Postby TheDuke » Sat Apr 17, 2010 12:24 am
One last change of direction, I hope. I'm about ready to build the garage that's going to contain Skeetr, so I've reverted back a little, and changed a few things, and made it look a little nicer. Put the door in the rear, again. The garage will be done before the summer is over.
You sleep with your head to the kitchen, in this version.
If you see anything that you don't understand, now's the time to tell me.
TheDuke
TheDuke
Images: 68
Postby TheDuke » Sat Apr 17, 2010 5:50 pm
Forgot to say that the new rev. is in the last 6 additions to my Album (The grey-blue ones).
TheDuke
Images: 68
Postby parnold » Sat Apr 17, 2010 8:55 pm
parnold
Images: 302
Return to Member Designs
