The HF harness came with the plug for the car, but my Subaru harness has the transformer that helps brighten up the trailer lights, so guess I'll go to Advance Auto and get some wiring stuff to fix the dang thing...
Miriam C. wrote::o Well I was gonna say cut and splice but. If you have a ground issue you need to see where that lil white wire is going. Should be going to the TV. If not them make it go there or get a battery clip and hook it to the TV to ground.
Arne wrote:bolted frames might have a problem because of paint and bad connections between the parts... mine was welded, so needed only a ground from the tow to the t/d... no problems...
wannabefree wrote:I first built up my frame with the HF wiring kit to get it licensed. Ended up running a separate ground wire to every light. Could not get a consistent ground through the frame, even sanding the connection points. You really have to sand all the frame to frame connections, too, and as suggested already use anti-corrosion compound. When I built for real the first thing I did was throw out the HF wiring and buy new lights with ground wires. The HF lights are junk. Just my opinion, of course.
Miriam C. wrote:Arne wrote:bolted frames might have a problem because of paint and bad connections between the parts... mine was welded, so needed only a ground from the tow to the t/d... no problems...
yeah I am thinking I remember someone else having that problem. I have an alum. bolt together canoe trailer that I had to wire all the way up to the front and join the grounds to the 4 flat....
