glassice wrote:after you build the box and you want to do a shape it will be easer to sand shet rock mud and get it clouse THEN you need to seall it I like to use bindo when you wet sand it wont wash the plaste away. then cover it with one coat of krylon primer sealer it is laytex then try to use flat epoxe paint over it over it it sands better Do 3 coats better to block sand then block sand and some more and yes more.And if you are happy now it time to do the glass .If you have a part that is done you can coppy It
glassice wrote:As you plan did you get a hitch cove with the tear on it you can incorporate it in to the side.look at fire place wood it has different shapes go to a sewing shop and look at there shape are do you save pigs are what ever that can be in corporate
