the most appropriate to bring back into service would be the manure spreader...............
boxcar wrote:Vintage is a good word .Can I use that from now on? [img]:thinking:[/img]
boxcar wrote:Never called anyone an idiot!!!!!! Safe driving habits equates to safe trailers. Your not a safe driver if your equipment is not as safe as it can possibly beeeeeeee.
Look Stoping distance is everything. So here is a challenge for everyone / Load your trailer and tow rig as you normaly do for an average trip. Now go find an empty parking lot (a large one)
Disconect your trailer from your rig. Now do a braking test run your car or truck up to 30mph and then stop as fast as you can. Mark the distance.
Do this same test with your trailer hooked up. You will be surprized.... I challenge you all, This could be fun , But be honest . Post your data on this site on a new thread.
Some states (ODOT) and a fuew others have started using stoping distance as a requirement for brakes on trailers.
This basicly takes all the loop holes out of the equasion. Trust me the way our government is going this may becomb the case in all states.
To me if I'm going to go to all the trouble to build a trailer, teardrop or tandem. I'm going to build it so that it will pass all requiremenst for all 50 states. Lets face it if you build to TEXDOTS requirements don't leave the state. According to TEXDOT standards (as quoted) you can tow a 4000lb trailer witha Yougo and be leagle (NOT TRUE) The requirements listed are guidelines only The BASIC RULE still aplies in all 50 states.
I'm not a perfectionest or a preacher (although it may seem that way)
I AM A master fabricator with a degree in engineering.And a parrent. I am in the buisness of building the verry things we on this website all love. I have bin for better than 30 years. And most importantly I am not trying to sell you anything.
If you have read this entire thread. I at no time have sed that the H/F trailer is a bad unit for it's designed use. In fact I have owned one (as I mentioned in my first or second response) but at 1700lb max load it may be a little light for most t/ds loaded. Especialy if your tow rig weighs less than 3800lbs because it can not be equiped with brakes as deliverd...
And at 1/3rd the weight of your tow rig you can not safly stop it . Simple math ... If you would like to prove me wrong go do the aformentioned test and prove me wrong.....Boxcar
boxcar wrote:![]()
boxcar wrote:Yes larwyn That is a tortion box!!! Now add walls and a roof and it is no longer a tortion box But a box beam.Your doors and rear hatch would not continue to operate if it was tortional. The walls and roof take all the tortion out of the equasion. Guess I did remember something.....
Look if you want to atack my profesion. Fine, But you better get to know me personaly before you atack me through insinuation.
Generaly speaking when someone resorts to mud slinging to bolster an argument it's because thay don't have a good argument in the first place.
I deal with this with my kid all the time . Didn't expect it here though.
If you feel the need to continue this discusion Larwyn lets start a new thread so others won't have to put up with us , and I'd be more than hapy to continue this discusion with you.....Boxcar
