The woodwork is fantastic! Great job!!!!
Lay them on, no worries.Hunterwinco wrote:Howdy Jiffy,
I have been lurking for about 2 years while trying to talk my wife into letting me build a teardrop or standie (probably a squidget).I have seen your thread before, but never noticed you were near by until I saw OOB below your username. I really like the looks of your trailer. How big is that Lincoln mig? The one that shows up in the pictures is 220V unit I think the model is a 180C. I also have a 110v unit in my other garage that I built my utility trailer with that would easily do the job. The 110v unit I bought used, it is a Lincoln as well and actually came from the Home Depot originally. How heavy/thick is the tubing that you used? 3/16" 2" x 3" tubing Where do you get your steel here locally? I got mine on route 4 in Alfred, might be Sanford as it is real close to the line. There is a place in South Portland by the Wok-In and the Red Wing boot store that I think is called American Steel that is a much bigger outfit, but I believe you can walk -up and buy direct from them. Be prepared to haul 20' heavy sticks home. Did you have to do anything with the state to register your trailer, or do you just go to town hall and tell them that you built a camper? Seeing as I built my frame and it is a camper I will have to have it inspected as part of the requirement to apply for a VIN number. The homemade utility trailer I built a few years back did not require a VIN application. I am not upset about having to apply for the VIN as if I sell the TD down the road it will make the transaction painless. I'm sure I can think of more questions!
