Trails in the Sand new updates 9-28-11
Postby Alan and Lianna » Mon May 17, 2010 8:48 pm
Well after 4 weeks of work, the teardrop is taking shape. I decided it was time to post some pictures. The rest are in the album.
Alan
Last edited by Alan and Lianna on Wed Sep 28, 2011 5:52 pm, edited 13 times in total.
Don't just dream about it!
Wake up and make it happen...
Alan and Lianna
Images: 389
welcome
Postby danlott » Mon May 17, 2010 8:54 pm
Welcome to the forum. Looks like your are well on your way. Post lots of pictures.
Dan
Hoplite Traveler Build thread
danlott
Images: 264
Postby grizz » Tue May 18, 2010 1:15 am
Welcome, and very tidy build you have there.
Greetings from England.
Rian.
grizz
Images: 29
Postby Rigsby » Tue May 18, 2010 5:21 pm
Very neat, looks like quality wood too. :thumbsup:
DOOIN IT THE YAARKSHA WAY--FA NOWT, THA NUS !!
Rigsby
Postby starleen2 » Tue May 18, 2010 5:58 pm
I see ya' hooked by a rental - way to go! Now it will inspire you to get yours finished :thumbsup:
starleen2
5th Teardrop Club
Postby greekspeedoman » Tue May 18, 2010 9:28 pm
What a strong start. I look forward to more additions to your build.
greekspeedoman
Lower Galley Cabinet Facing
Postby Alan and Lianna » Wed May 19, 2010 3:43 pm
I worked on the lower Galley Cabinet Facing today, we drew it up last night
And I cut out the openings this morning
And test fitted it in place. I know it looks like it is in backwards, but when we set it up we put the bulkhead in backwards, we will correct upon final assembly.
Alan
Alan and Lianna
Images: 389
Postby YuGun » Wed May 19, 2010 4:03 pm
Very beautiful trailer.
ı like it. Take it easy.
YuGun
Postby Alan and Lianna » Fri May 21, 2010 3:50 pm
After some practice cuts with my wobble dado blade
I cut out the sliding door channels
then I cut the doors to fit
and added some finger holes.
I placed the doors on another piece, hoping to reduce tearout on the back side, but still had some. I think next time I will drill half way through, flip it over and finish drilling from the other side.
Alan
Alan and Lianna
Images: 389
Postby teardrop_focus » Fri May 21, 2010 5:16 pm
Nice work on the galley!
Good-looking build. :thumbsup:
teardrop_focus
Images: 127
Postby grizz » Sat May 22, 2010 1:15 am
That is seriously neat.
I have miles of tearout, but fortunately I was able to camouflage most of it 8)
You seem to have maximised the galley cabinet space. Well done.
Rian.
grizz
Images: 29
Postby Alan and Lianna » Sat May 22, 2010 11:38 pm
We had too much of a gap where the side wall fits into the trailer so we cut 3/4" pieces of wood and filled in with liquid nails. We made a piece that was 1/16" deeper to push the wood down to the correct depth.
We drilled pocket holes every 12" along the edge of the floor.
Checked pocket hole screw length and decided that 1 1/2" worked best.
We had to run the wiring for the exterior lights before gluing the interior skin
Now we glued the interior skin onto the side wall, using NTPPW (new technology- potted plant weights)
We added few more clamps. Can you really ever have too many of these?
We removed the bondo from this gap and added a trough for the wiring.
Decided to use screws to hold the skin on since we are going to paint the walls. Oh, and apparently we did NOT have too many clamps-actually ran out
We are using spline joints to join the 2 side walls. After using the router to cut 1/8" spine joints, we are testing the fit-perfect.
We cut 1/8" by 15/16" splines to fit into spline joints.
After 4 weeks of working in the hot, south TX sun, fellow teardroppers, Big-D, Brandi, Richard & Diane offered us a huge garage space to finish our build, so we are packed up and ready to move.
We are so appreciative for this gracious gesture. Without proper shelter, we have been building and storing all our work and supplies in our living room, kitchen, hall & bedrooms (as you can see from previous pics)
Lianna & Alan :)
Alan and Lianna
Images: 389
Postby Alan and Lianna » Mon May 24, 2010 3:07 am
What a day! We got up early and got dressed for work.
We skinned the galley walls, cut the hatch sides, ran some wires, glued some spars, recut and refit some pieces, lost a piece?, epoxied some wood, drilled, screwed, counter sunk, routered, glued, clamped, hammered, and finally assembled the walls on the trailer for good.. Image
We worked up till midnight, so needless to say we are a too whooped to give a really good update, but posted some more pictures in the album
Alan and Lianna
Alan and Lianna
Images: 389
Postby stomperxj » Mon May 24, 2010 9:35 am
Lookin great guys. Awesome progress!
stomperxj
Postby Alan and Lianna » Thu May 27, 2010 4:15 pm
After coating all the walls with epoxy, we filled in the voids, sanded smooth and applied a coat of KILZ primer.
We framed the hatch.
Then we skinned the hatch interior.
And on my sliding doors, the lower track was bowed in, so I cut a spacer that once wedged in place would hold it straight.
Alan and Lianna
Alan and Lianna
Images: 389
Users browsing this forum: MickinOz and 17 guests
