Sly1990 "Cmd Post" UPD 07-19-10 - 120V Electricity
Postby sly1990 » Sat May 15, 2010 9:45 pm
This will be a long thread (in time and in length).
I'm only working on it half a week-end at the time.
Welcome to my build Journal..!
I was looking for ultralight camper but I found em way too much expensive and/or to big for me....
I was needing something small (Not bigger/Larger than my car), Something light that I wont have
to deploy everytime I go on a 1 week trip
Then, a miracle happened while surfing the web.... I found this forum.... :thumbsup:
After months reading this forum and looking at the hall of fame, I tought it was
time to build my own Teardrop...
Needs :
Small Trailer Camper. not wider than my car. ( 98 Crown Victoria 6ft wide)
No need to deploy anything like a tent
Can Sleep confortably in full extention. (I am 6'3" tall)
Lowest Cost Possible (Ideally Under 3k)
2 doors
Have confortable space for 2 wide.
Have a Propane Stove (Back counter top)
Full 15A AC Circuit (1800W Inverter + DC31-280 battery + future solar panel)
24" HDTV, CD/MP3 Radio & 4 spkr
Space for Cooler/Electric Cooler or 12V Fridge.
Vent Trap built to accept a future camper roof Climated Air.
Finish:
Side wall (exterior) : White Plastic
Side Wall + Ceiling (Interior) : Sand & Varnished Spruce
Floor : Nailed & Glued Laminate Flooring.
Top : Metal Finish
Project Dimention :
Overall Cabin Length : 9' 6"
Overall Cabin Width : 61"
Overall Cabin Height : 54"
Weight : <unknown>
A friend is gonna build me custom trailer at the end of July from what I builded.
If lucky enough, I could have it done for the end of august. :twisted:
This week, I was lazy and tired (had a rough week) and only went out of bed at 12:00.... :lol:
Today, I had to get the material for the floor and some for sidewalls.
Bill of Material (1st Week)
1x == 5' x 8' x 3/4" Water Resistant Plywood == 100$
2x == 4' x 8' x 1½" Isolating Foam R7.5 ======== 60$
3x == 4' x 8' x ½" Plywood =================== 60$
10x == 2" x 4" x 10' Beam ======================= 30$
1x == Metalic Tape ============================= 10$
3x == Construction Glue Tube =================== 25$
1x == 1" Screw (Pack of 100) ==================== 8$
1x == 1½" Screw (Pack of 100) =================== 8$
1x == 2" Screw (Pack of 100) ==================== 8$
Total today : 309$
Grand Total Yet: 309$
Materials
Since I have no trailer yet, I need a dolley to move the TD out of the garage when i'll have to move it out.
Starting building the Floor.
Finished Floor. I underestimated the Glue I'd need for the floor. I need more to install the 1/2" plywood to close the sandwich.
Ok... That's it for this week...
Monday, I'll scan my paper plan at work.
sly1990
Postby BillZ » Sun May 16, 2010 7:55 am
Sounds like a great build project!
I want to see the pics but they won't come up.
BillZ
Postby grizz » Sun May 16, 2010 8:03 am
Great planning there.
I suspect you may have loaded the pics, and then deleted the source.... ?
Anyway, I am sure you will enjoy the build and cameraderie on here.
Like you say, this site is a God send.
Greetings from England.
Rian.
grizz
Images: 29
Postby sly1990 » Sun May 16, 2010 9:47 am
Thank for telling me...
I'm hosting the pic on my home server...
I guess it's maybe because you guys have a DSL connection. :thinking:
Most DSL Provider block port 80 on non-commercial IP Adress...
Cable ISP does not block em....
I forgot to add :8080 at the end of the IP for you to use a Mirror Port for HTTP request...
I also had to to do this to make the Gaming Forum I host visible to everyone...
It's should work now... :thumbsup:
sly1990
Postby sly1990 » Sun May 16, 2010 7:22 pm
Today, I bought :
Abigger caulking gun for bigger glue tube... 13$
3x 850ml King size Glue tube 33$
13x Beam 2" x 3" x 10' 30$ (for wall structure.)
48sq ft (2 pack) of laminated flooring 50$
Total : 126$
Grand Total : 435$
Applying glue before screwing the 1/2" plywood.
Glueing while installing the Laminated Floor.
Finished Floor
Finished and Drying....
sly1990
Postby sagebrush » Sun May 16, 2010 8:48 pm
You are off to a great start! :applause: Don't worry about no trailer, minor detail that will be corrected in time. ;) Will
We ain't skeer'd of the dark!
Living large in a small way!
sagebrush
Images: 161
Postby sly1990 » Mon May 17, 2010 9:31 pm
My "Sideview" paper plan....
Simpler than that, its no plan at all.... :lol:
One square = 3 inches.
sly1990
Postby Rigsby » Tue May 18, 2010 5:28 pm
Its coming on great :applause:
In my opinion though, the wheels could do to be 2 squares further forward, to keep the tongue weight lower, especialy if your tug is a normal car, and not a huge merican truck
steve
DOOIN IT THE YAARKSHA WAY--FA NOWT, THA NUS !!
Rigsby
Postby mikeschn » Tue May 18, 2010 5:49 pm
sly1990 wrote:My "Sideview" paper plan....
I like the plan!
Postby starleen2 » Tue May 18, 2010 5:55 pm
The floor looks good and solid! :thumbsup:
starleen2
5th Teardrop Club
Re: Sly1990 - 1st Teardrop Build
Postby Jst83 » Tue May 18, 2010 8:03 pm
sly1990 wrote:Since I have no trailer yet, I need a bogey to move the TD out of the garage when i'll have to move it out.
Looks like a good start love the idea for the dolly to move it around on. I'm building one also without a trailer and have it on little saw horses in the corner so it's the height it will be on the finished trailer.
That would make it so handy to pull the larger tear out of the garage and the roll the little one to the middle to work on and then back.
Thanks for the pic :thumbsup:
Jst83
Images: 215
Postby Ageless » Tue May 18, 2010 8:20 pm
I like the profile,but . . . .
where'd ya get the 7 lug wheels? :lol:
Ageless
Postby sly1990 » Tue May 18, 2010 9:54 pm
Thanks guys... :D
About the 7 lugs wheel, it was more to visualise a wheel and i thought of a simple 90's Mustang Honey Comb Mag.... :lol:
About the wheel 2 more square closer to the front, yeah, i admit it will be better placed... thx for the advice.
Is there a suggested or min/max weight on the tongue of the trailer?
Today I bought :
1L of Anti-Rust Paint 26$
Roof Vent 14" x 14" (at Canadian Tire) 45$
Total : 71$
Grand Total Yet : 506$
Maybe thursday or Friday ill paint the whole thing (Except the laminated floor naturaly) with Tremclad Anti-Rust (Aluminium color) to seal the whole thing.
My dad applied that on cheap 1/4 plywood (to cover the side of his gazebo during winter) and i was impressed by the results.
It's been 6 years exposed to elements all year long and it still look great.
No mildew, no cracks, no water infiltration....
I wrote to Hehr Internationnal for sliding Window and they have a Canadian Distributor.....
I want these windows (The one on the right)
Lucky me!, I live at 20 min from the only distributor in canada.... 8)
Need to call them tomorrow...
I hope there price arent Sky High!.... :worship:
I need two 15"H x 24"W black & tinted radius sliding window for my doors but I still dont know their price...[url][/url]
sly1990
Postby Rigsby » Wed May 19, 2010 5:13 pm
Ive just googled crown victoria, and can see it is a fairly big strong car. Your tongue weight will depend on what sort of frame you build, if you build good and strong you can go heavier, but consult your cars handbook for the maximum you can go to
Rigsby
Postby sly1990 » Sat May 22, 2010 8:54 pm
Today I bought :
1 Blue Foam 28$
10x 2"x3"x8 25$
10x 2"x3"x10 18$
1x Glue Tube King Size. 11$
3x Spruce 1/4 4'x8' (one sanded side) for int. walls. 66$
Total : 148$
Grand Total Yet : 654$
Finally, while i was marking the wood for the cuts, I decided to modify a little bit round shape for the camper....
It will be easier this way.... 8)
I started my sidewalls today....
Long week end = Lot to do to the TD....
The Tremclad Painted floor structure. (I forgot to take photo before flipping it upside down.)
Marking the round shapes for cutting.
Cutted 1/2" plywood
Starting sidewall Framing
Taking a look at the wall temporary in place.
I decide to Fix the 2"x3" base of the wall frame solidly on the floor.
Later, i'll add the wall to it. IMO it will be stronger that way. Ill have a 5"½ wide
surface to glue and srew the whole thing on the side.
Started the Wall insulation....
I'm an idiot..!!! I just bought a 4'x8'x2" of blue foam.... It was misplaced at the local store.
So I didnt look at the size... I realised after cutting the 1st piece the extra ½"...
So I cant return it... wasted 28$...
Lucky me i had a second one so i could start the wall insulation.
sly1990
