dh wrote:I have a lead hammer I have for this type of thing, you can give it hell and not worry about dinging anything. Brass hammers work well too, but with lead I can re-cast a head in house.
Dale M. wrote:I chose a better quality than HF (Craftsman) but this will do the job....
eamarquardt wrote:Dale M. wrote:I chose a better quality than HF (Craftsman) but this will do the job....
My Makita is still going strong after almost 30 year of use!
Cheers,
Gus
Larwyn wrote:But if you are already half deaf and can hang on for the ride I suppose you could say that it still works...... :lol:
Larwyn wrote:Since WD-40 has been mentioned, I thought I might mention this, I have read that a 50/50 mixture of automatic transmission fluid and acetone will result in a more effective penetrating oil than any of the commercially available products.
"The April/May 2007 edition of Machinist's Workshop did a test of penetrating oils where they measured the force required to loosen rusty test devices. Buy the issue if you want to see how they did the test. The results reported were interesting. The lower the number of pounds the better. Mighty interesting results for simple acetone and tranny fluid!
Penetrating oil . Average load .. Price per fluid ounce
None ................. 516 pounds .
WD-40 ............... 238 pounds .. $0.25
PB Blaster ........... 214 pounds .. $0.35
Liquid Wrench ..... 127 pounds .. $0.21
Kano Kroil ........... 106 pounds .. $0.75
ATF-Acetone mix.. 53 pounds .. $0.10
The ATF-Acetone mix was a 50/50 mix (1 to 1 ratio)."
I have not used it myself but I do have the ingredients sitting on the shelf waiting for a likely suspect. I have heard that the mixture does not store well so it is better mixed in small batches as needed.
teardrop_focus wrote:Late to the thread here...
In the pic above, is it the bearing's inner race that's glued (sic) to the spindle?
In that case then cut a couple of v-grooves into the race approx 180 degrees apart, almost to the spindle but not quite; then take a chisel and crack that puppy off o' there...
:hammer:
.teardrop_focus wrote:Late to the thread here...
