angib wrote:Billy, the baggage trailer plans are here:
http://teardrops.us/userfiles/53/mini2plan.pdf
http://teardrops.us/userfiles/53/mini2construct.pdf
http://teardrops.us/userfiles/53/mini2geom.pdf
Andrew
dwgriff1 wrote:The tongue and the hitch should be the right height so the trailer rides level. Is that a fair assumption?
In a pickup you can get all sorts of drop hitches. But not so for small cars.
With a simple "A" frame tongue how could/would you raise the tongue height say 3 or 4 inches? AND, make it look good too!
How about using Tube rather than angle. Tube can be bent in a muffler shop, for instance.
Is that doable?
dave
teardrop_focus wrote:With a simple "A" frame tongue how could/would you raise the tongue height say 3 or 4 inches? AND, make it look good too!
I am facing this exact dilemma myself currently... I need to raise the 2 X 2 tongue 4.5 inches on my particular setup... I've only spent part of one day searching (but have almost exhausted all local references) for someone in soutthern California that has a mandrel bender for 2-inch square tubing.
The next idea is stacking the tube like BobHenry as just pictured... or fabricating a two 30° bends out of plate and stitching in into the tongue.
Dummy
Might this work...
