Tackett wrote:How durable is mill finish .30 aluminum?
planovet wrote:Tackett wrote:How durable is mill finish .30 aluminum?
I would think .30 aluminum would be quite durable if not heavy and a bear to bend.(Just giving you a hard time.)
I used white .040 for my roof and it is perfect. Easy to bend and very durable. I found my 5' wide material at a local sign shop. You can also find it at trailer repair places. Your color choices may be limited but just call around and you will find it.
planovet wrote:To float or not to float, that is the question. Search and you will find compelling augments for both sides. I floated mine without any adhesive. It's just held on the edges by some staples and the trim. It worked great for me.
madjack wrote:Tackett, I float my AL skins...no adhesive...relying on vents, fenders lights, trim, etc. to hold it in place...I do use a couple or 3 air driven staples to hold the sides in place while installing, these staples are covered by the trim...this technique works very well and was first recommended to me by a commercial TD manufacturer...the problem with using adhesives is different expansion rates between the AL sheet and the substrate it is covering which can cause "oil caning"(bubbles under the skin)...folks have done it both ways successfully...I prefer to use this method since it eliminates a rather messy step in the build...if you do decide to use an adhesive, you may wish to lightly sand the AL to give some "tooth" for the adhesive to stick too..........................
p.s. click the search button above and enter "float AND skins" for more info...enter it EXACTLY as I have typed it.....MJ
Tackett wrote:
.30 .030... what a decimal place worth?
A couple hundred pounds!
Tackett wrote:What do you use for corner trim (where the top meets the side panel)? The pieces I have are L shaped, with the long leg going on the top, and the short leg on the side.
planovet wrote:Tackett wrote:What do you use for corner trim (where the top meets the side panel)? The pieces I have are L shaped, with the long leg going on the top, and the short leg on the side.
Not sure what MJ used but I used a insert molding that you can get at most RV stores. Comes in mill finish and white mostly. You can find inserts in many colors.
ubear7 wrote:Is the molding pictured easily worked around the curves with ease and without crimping, or is annealing needed? I like this option, it leaves a very clean look.
Users browsing this forum: Bing [Bot] and 5 guests
