Corwin C wrote:I'm assuming that you're grounding your battery or TV connection to the frame.
I would put it wherever is protected from the weather as much as possible and easy to get to (because you will be visiting it from time to time). I use a little di-electric grease on it as well to help keep corrosion at bay. If you're using a bolt-together trailer, I would still run a separate ground to each fixture rather than relying upon the frame.
S. Heisley wrote:Does it matter where I put the grounding screw?
angib wrote:S. Heisley wrote:Does it matter where I put the grounding screw?
Nope. Won't work for long wherever you put it....
Like everyone says, wire separately from the frame.
Andrew
S. Heisley wrote:Thanks, all. I did it both ways, so, I'm covered.
