The harbor freight trailer middle and end pieces sit inside the side pieces causing them to be about 1/8 inch lower. This will bow the floor down slightly when bolted down. What did any of you use as a spacer?
Carl01234 wrote:Got my window yesterday. How is the window attached on the outside? Does the trim ring screw through the wall and then into the window?
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?VISuperSize&item=260485532659
