eamarquardt wrote:I don't think I'd plug weld the perimeter of the outside pipe to the inside pipe if there is a quarter of an inch difference.
[/quote]dh wrote:eamarquardt wrote:I don't think I'd plug weld the perimeter of the outside pipe to the inside pipe if there is a quarter of an inch difference.
What is the OD od the axle tube? Let's find out!
Would it be possable to get a piece of tube the same as the axle is made of?That's knda what I'm asking also.
So, you could cut the axle in half, weld in a piece of tube in the center, grind the welds down, then slip a piece of pipe, perhaps custom bored to fit, over the welds, then weld these on. That would be pleanty strong. No I'd tack on angle iron first to establish surfaces that could be clamped when reassembling the axle. This way you could keep the original geometry of the axle intact. I'd use tubing/pipe the same dimension as the original beveling both halves of the axle and the piece to be inserted so you can get to the root of the weld easily. I'd turn a couple of pieces of bar stock or smaller pipe/tubing to insert in the bore to back up the welds so they are 100%. Then, I'd grind, file, sand the new weld flush to minimize the lines of stress (by making it smooth, it will actually be stronger than with a bead of weld there). When finished, the axle (depending on how much effort you put into the grinding, filing, sanding) would/should be virtually indistinguishable from a "factory" axle. I have a lathe so machining two backup pieces to put inside the three sections being welded would only take a few minutes. Even if the ID's and OD's were slighly different, if I were provided with a short sample of each, I could make a couple of plugs that would work. I'd do it this way because I have the capabilities and it wouldn't be that much work. You could also insert a solid piece of barstock inbetween the two halves of the axle with the ends turned down to slip inside the original tubing/pipe. Lots of options.
What is the OD of the axle tube?
Would it be possible to get a piece of tube the same as the axle is made of?
So, you could cut the axle in half, weld in a piece of tube in the center, grind the welds down, then slip a piece of pipe, perhaps custom bored to fit, over the welds, then weld these on. That would be plenty strong.
I like the sound of that
eamarquardt wrote:dh wrote:eamarquardt wrote:I don't think I'd plug weld the perimeter of the outside pipe to the inside pipe if there is a quarter of an inch difference.
