I am getting ready to coat the bottom of my floor with roofing tar and started thinking about sealing up other areas.
My sidewalls have a dado that slips over the plywood floor. I have never used roofing tar so I don't know if this would work or not, but I was thinking of running a thin layer over the end grain of the plywood before slipping the wall on. Would that work? I am thinking mainly of the glue adhesion. I think I will be using PL premium for the joint (if not it will be Titebond III). Could you run a thin layer in other areas as well - along the bottom 2 inches of the outside wall or the top of the wall and then set the roof ply on? I am covering the outside in aluminum so this would all be done prior to skinning it. Thanks
Ryan
