Swing-up top lifing aids on the Squidget GT?
Postby Ageless » Sun Jul 25, 2010 10:58 am
The top on the Compact Jr. lifts different; first the front lifts and locks; then the rear. I'm no weight-lifter (all 136 lbs of me) but I have no trouble raising the top.
Ageless
Postby cracker39 » Sun Jul 25, 2010 11:43 am
Since my last post, I’ve been doing some redneck engineering as I’m prone to do a lot of the time (like my plywood mower replacement wheel for example). Here’s my redneck lift.
Using the laws of physics in a typical redneck fashion, I came up with my using leverage to lift the top from outside of the trailer. First, buy two lengths of closet pole and some PVC that the closet pole will fit inside the tube for reinforcement. Or, steel conduit could be used instead of PVC and wouldn’t need the reinforcing. Also buy two L connectors.
Cut off two 3â€
Dale
cracker39
Images: 233
Postby starleen2 » Sun Jul 25, 2010 11:54 am
the design works - but you'd better have the camper coupled to the TV or you'll get a nice see -saw action going trying to lift the top (the wheels act like a pivot too!) with the downward force exerted at the rear. perhaps some jacks on the rear would stabilize and keep this from happening. Also is this lift mechanism going to be on both sides? I can see it becoming wedged to one side or binding while trying to lift :thinking:
starleen2
5th Teardrop Club
Postby john » Sun Jul 25, 2010 1:11 pm
Ya, that's the ticket!
But if you want to keep the complexity at a higher level you could always use a telescoping paint-stick. 'Bout the same cost.
Build I -- Scenic ---
http://www.flickr.com/photos/8121727@N04/
Goto the Tear Build file
Build II -- Scenic II ---
viewtopic.php?t=29603
Build III -- Scenic Solo---
viewtopic.php?f=50&t=50324
Travel Blog----Now without Political Commentary
http://polifrogblog.blogspot.com/2009/0 ... -2009.html
The Constitution was ratified, not an interpretation thereof...
Penomeli ikibobo
john
john
Images: 261
Postby cracker39 » Sun Jul 25, 2010 1:38 pm
As usual, I over-engineered my lift. Forget the hinge plates and bolts. Put some 1â€
Dale
cracker39
Images: 233
Postby cracker39 » Sun Jul 25, 2010 1:48 pm
starleen2 wrote:the design works - but you'd better have the camper coupled to the TV or you'll get a nice see -saw action going trying to lift the top (the wheels act like a pivot too!) with the downward force exerted at the rear. perhaps some jacks on the rear would stabilize and keep this from happening. Also is this lift mechanism going to be on both sides? I can see it becoming wedged to one side or binding while trying to lift :thinking:
I doubt that 3 puonds of pull down in the back would move the camper weighing 1400 plus pounds and close to 200 pounds on the tongue jack in front if that's what you meant.
No seesawing, no binding of the cap either. The cap can't twist and it can't move any way but straight back and up as it is hinged to full width end panels that are also hinged to the roof. Even one pole would lift it straight. When one side is lifted, the other side has to go with it in a straight line.
Dale
cracker39
Images: 233
Postby john » Sun Jul 25, 2010 2:37 pm
No, no, no! Simplicity? You're going the wrong way!
Stop thinking like a Russian. This not a Makarov.
Think German, think Mercedes... :lol:
Love it! :applause:
Penomeli ikibobo
john
john
Images: 261
Users browsing this forum: Bing [Bot] and 6 guests
