Rog good to see you back... I want to see those pergola pictures.RogHodge wrote:On last question about the torsion box (yea right)
When creating the webbing inside the box I will need to create a span that overlaps the frame. Some of the spacers inside the box will be able to run full length and others will be short ‘filler strips’ if that makes sense- so… should the long pieces run sideways or front to back. I’m considering a half-lap joint at the intersections which may be the best of both worlds. The other option is that I’m seriously over thinking this and I just need to get going.
For what it’s worth I’m settling in on 1/8 bottom- ¾ ‘furring strips- double 1/8 top (double the 1/8 rather than 1/4 to get more plys from cheap wood probably glue the sheets together in place)
Nothing wrong with that, it's better than under thinking it.The other option is that I’m seriously over thinking this and I just need to get going.
