Being as dry as it is there using card board is great way to help with the heat
It look like you have been doing this forever
Woodstramp wrote: ... then a foam/resin/glass cloth shell should be like a tank.
Starleen2 wrote: who are ready to tout the advantages of epoxy and how BRITTLE resin is?
Changer wrote: Now, question for the fiberglass experts who are mentioning using foam- won't polyester resin disolve foam?
Changer wrote: Oh, and other question, how is strand fiberglass like that applied? Put into resin and smoothed on,or what?
eamarquardt wrote: I believe the fellow used a "chopper gun" to lay his glass.
kennyrayandersen wrote: Fiberglass isn’t a resin. The resin is the matrix material that keeps all of the fibers in place so that they can react the load. The matrix itself can be either polyester or epoxy (or a few other things). Either will work and each has advantages. Polyester is cheap; epoxy is not. Epoxy is higher strength and more stable and is used in the aerospace industry along with high-performance marine applications whereas Polyester is mostly used in lower-cost marine applications (think recreational boating).
kennyrayandersen wrote: So, as Gus states you have to use a ‘real’ structural foam.
kennyrayandersen wrote: One thing that should be noted for chopped fiber (the kind you spray on to save labor). It isn’t as strong so you need more of it. It’s not that the chopped fiber won’t work; it’s that the fibers are shorter so the weaker resin is doing more of the work and so more chopped fiber is required to carry the same load. More chopped fiber also means more resin to hold it so the overall weight goes up. As has been discussed several times before, the teardrop loads are not that high, so it’s not a big issue – as far as strength is concerned.
kennyrayandersen wrote: The easiest way to duplicate the cardboard build with a ‘structural’ material [rather than the cardboard] would be to use the Home Depot/Lowes foam and layup fiberglass and epoxy fabric over it…
kennyrayandersen wrote: It would probably be a lot faster to spray on the fiberglass. but without taking time to build a mold, the exterior would look all rough like chopped fiber and thus would have to be sanded a BUNCH to make it look smooth (if that were important to you).
glassice wrote: It look like you have been doing this forever
glassice wrote:don't fell bad that you did not use a chopper gun there $14,000 Us
pete42 wrote:First I have to say "CUTE KIDS"
pete42 wrote:Then building a teardrop using mat fiberglass must have been very hard to do. I built two fiberglass airplanes Burt Rutans Veri-eze
pete42 wrote:The foam like your cardboard is only used for the shape we wanted it does not add any strength.
Steve Smoot wrote:Wish you lived next door...
mezmo wrote:You mentioned that you were working on a folding trailer design. Have you made any progress?
mezmo wrote:I looked through
your album and noticed some pics of the ZA Off Road
trailers that I find quite interesting. I came across them
while searching on the web. The Jurgens Safari,
the Imagine and the Conqueror ranges all contain great
ideas for maximizing minimal camping. I wonder if any
of those manufacturers ever considered exporting them?
I have a feeling though that high cost is probably a factor
with them.
Woodstramp wrote:Oh, a young'n here told me how to pronounce South Africa like you natives. "Suta-freeka"....is that correct?
mezmo wrote:If you have a house - you have a hobby.
starleen2 wrote:Hey now - throw the yellow flag! time out. What's this about fiberglass resin? Where are all the epoxy folks (and you know who you are) who are ready to tout the advantages of epoxy and how BRITTLE resin is? surely this thing is going to fall apart because he used resin instead of the better and more expensve epoxy! enough of the rant - dude that is some well laid glass work and an excellent concept of materials.
IASCOTT wrote:Barnie did you install any hard points where you install the hinge screws for the doors and the hatch. Also the mounting points to the trailer frame.Scott
michaelwpayton wrote:starleen2 wrote:Hey now - throw the yellow flag! time out. What's this about fiberglass resin? Where are all the epoxy folks (and you know who you are) who are ready to tout the advantages of epoxy and how BRITTLE resin is? surely this thing is going to fall apart because he used resin instead of the better and more expensve epoxy! enough of the rant - dude that is some well laid glass work and an excellent concept of materials.
STARLEEN2,
I can't speak for others that you may be referring to as "epoxy folks," but the concerns I have posted in other threads relating to the use of polyester resin have all been with respect to its use with plywood. Please... try to understand... the fact that epoxy resin is superior to polyester resin when used in conjunction with plywood... has nothing to do with what this builder has accomplished here with polyester resin.
starleen2 wrote:michaelwpayton wrote:starleen2 wrote:Hey now - throw the yellow flag! time out. What's this about fiberglass resin? Where are all the epoxy folks (and you know who you are) who are ready to tout the advantages of epoxy and how BRITTLE resin is? surely this thing is going to fall apart because he used resin instead of the better and more expensve epoxy! enough of the rant - dude that is some well laid glass work and an excellent concept of materials.
STARLEEN2,
Duely noted - But I will be a resin guy. I think that fact that this guy did use resin instead of epoxy shows that resin can be used successfully. That is what i wanted to highlight for those who are reading this. I find it hypocritical that those who use epoxy exclusively do not want to challenge a builder who uses it exclusively in their build and it worked out just fine. This builder demonstrates that. I say Kudos to his reasourefulness and to doing something innovative. BYW how's the Benroy coming along?
parnold wrote:I hope the "resin wars" posts stop as they are detracting from an awesome build thread!
