silver spaceship
Put on the walls today.
Postby R. W. Alexander » Mon Jul 19, 2010 8:36 pm
I bolted the walls to the trailer floor today. And put in all the framing in at the same time.
My trailer will have a awning with a window in the front of the trailer. The framing for this awning is constructed like the galley hatch except for a raised L shaped edge on the inside where the inside bottom edge of the awning butts up against the bottom lip of the front opening. When I put on some aluminum I will take some close up photos of the window edge. I am hoping that this set up will prevent any water from getting inside the trailer, when driving in the rain. Water under pressure can work it's way into just about anything.
R. W. Alexander
Images: 77
Skinning the top and front
Postby R. W. Alexander » Wed Jul 21, 2010 11:49 am
I put on the top and front panel today. I allowed a 1/2 inch overlap on each side, and put on some clamps on each edge, and used a rubber mallet to bend over the aluminum. Then I pulled off the top. Put on some sealant on the inside of the formed bend, and put the panel back on and tapped the flange tight against the vertical wall panel, drilled and counted sunk some holes, and put in stainless flat head screws.
[img]
Image[/img]
R. W. Alexander
Images: 77
Postby AJP » Tue Jul 27, 2010 5:13 pm
I really like what you did with the aluminum, and thanks for a good cheap source of it. I am planning out a build and wanted to do an aluminum frame but was worried about the cost.
AJP
Postby Cliffmeister2000 » Tue Jul 27, 2010 5:21 pm
Nice build journal! :applause: :applause:
Hijack Alert!!!
I noticed the name of your teardrop, and thought you'd enjoy seeing another silver space ship, though it's a bit smaller than yours.
This is what the builder sleeps beside!
I don't remember his name, but he's from Topeka, Kansas. Great guy, great build!
God Bless
Cliff
♥God. ♥People.
1 John 4:9-11
My Teardrop build pictures
Cliffmeister2000
Titanium Donating Member
Images: 157
Postby R. W. Alexander » Tue Jul 27, 2010 5:58 pm
That is one beautiful build. The craftsmanship of the sheet metal is awesome. :thumbsup:
R. W. Alexander
Images: 77
Postby R. W. Alexander » Thu Jul 29, 2010 10:21 am
Put up the front stargazing awning this week. It is insulated and is adjustable. The two wooden bars at each end have notches that fit into a slot cut out in the sides, by the window screen. At the end of the wooden bars inside the trailer I will install a latches that will apply pressure to the awning so the gasket will get compressed against the outer wall of the trailer. I plan on adding some stainless catch latches to the outside edge of the awing for extra safety, in case something loosens up inside while towing. That's cheap $9.00 insurance.
This is a close up view of the awing ledge. It is raised up 3/4" and sloped about 10 degrees down and caulked.
This is a photo of the P shaped gasket I got from McMaster Carr 93085K913.
A photo of the window screen installed.
This is a photo of the awing closed up. The bottom of the awning is placed well below the wind profile of the car. This should take care of wind driven water. But the fine mist kicked up by the tires, will could be the problem with water getting in. I plan on putting on a layer of epoxy on all wood surfaces/edges that a fine water mist could get into.
In the last few weeks I have learned a lot about building these trailers. This one will be done within 2 weeks or less, Ready for a trip to Yellowstone
Some of the things I have done could be better, or done easier but that's how you try to learn.
R. W. Alexander
Images: 77
Postby Papi » Thu Jul 29, 2010 1:29 pm
:applause: Great aluminum work!
I dream of a day when a chicken can cross the road without having his motives questioned.
Papi
Images: 50
Postby Cliffmeister2000 » Thu Jul 29, 2010 1:30 pm
I love the stargazer window! :applause: :applause:
God Bless
Cliff
♥God. ♥People.
1 John 4:9-11
Cliffmeister2000
Images: 157
Postby High Desert » Thu Jul 29, 2010 2:59 pm
Thats a great idea! Most folks worry about building one curved hatch and you've built two on the same trailer. Bravo!! :applause: 8)
Shaun
High Desert
Images: 27
Postby R. W. Alexander » Thu Jul 29, 2010 7:08 pm
High Desert wrote:Thats a great idea! Most folks worry about building one curved hatch and you've built two on the same trailer. Bravo!! :applause: 8)
Thanks to everyones nice comments. I really appreciated them.
Today was productive. I got lots done.
This first photo is the upper storage. I plan on putting in some mirror acrylic panels that will slide to the sides with a lasered mountain scene. Since the acrylic is 1/8" wide I found that a glue joint bit that I had would cut out the perfect spacing for the acrylic panels. 2 each 1/8" slots with 1/8" spacing, 1/8" deep.
Here is a photo of the finished shelf's. The shelf's are made from 3/8" sanded ply leftovers. I made 1/2" square furring strips to strengthen the spans on the shelf's.
And here are some photos of the front storage/headboard area.
R. W. Alexander
Images: 77
Fenders attached and galley vents
Postby R. W. Alexander » Fri Jul 30, 2010 4:39 pm
I did the fenders today. I had some steel fenders that I bought a few years back from Northern tool, and recycled them into the Tear Drop. I cleaned them up and took some leftover steel from the trailer frame and cut some tabs to weld to the fender.
I then drilled some 3/8" holes for the 5/16" bolts that would attach the fender to the trailer walls. And painted the fenders with primer and a silver top coat.
I then drilled 3 holes thru the walls of the trailer and attached 3/8" bolts with large fender washers on the inside of the trailer wall. I also put in some black fender welt that I got on Ebay between the outside wall of the trailer and inside of the fender.
The finished fender.
I also installed some vents for the galley area. One vent is placed at the top end of the galley and the other on the opposite side on the low end. This should allow for cross ventilation, and keep temperatures a bit lower in the galley. The vents have a feature where you can close them from the outside to prevent water from getting into the galley.
Upper vent
Lower vent
R. W. Alexander
Images: 77
Postby Ratkity » Fri Jul 30, 2010 6:20 pm
Absolutely beautiful inside and out. I love the stargazer window!
Hugs,
Ratkity
Ratkity
Postby Rlowell » Sat Jul 31, 2010 11:48 pm
:applause: :applause: You gotta love the toys!! Great job on this build.
We are looking forward to seeing the final product. 8) 8)
Rod
Plan your work...work your plan...at least that's the plan. Oh, just do it anyway!
gallery/image_page.php?album_id=1425&image_id=76342
Rlowell
Images: 42
Postby S. Heisley » Sun Aug 01, 2010 9:26 am
This is shaping up to be a real beauty! :thumbsup: :applause:
Postby R. W. Alexander » Wed Aug 04, 2010 2:41 pm
Ratkity wrote:Absolutely beautiful inside and out. I love the stargazer window!
Hugs,
Ratkity
Thank you, but I think the mosquitoes won't like the stargazer window.
R. W. Alexander
Images: 77
