steve smoot wrote:No matter how long it has taken, you are doing a nice job...![]()
MKE_Tear wrote:Not much of an update but...
1. The height of the door was raised one inch (before the cut -- should have said that earlier),
2. Primed the rest of the inside (been doing 3 coats to be extra-sure/safe),
3. I have been filling the screw holes and the gaps where the plywood was stretched, and
4. Test fit the window -- I can see progress!!
Cliffmeister2000 wrote:My trailer weighs in at 1,340, and I used 1x lumber for the framing. I hope you meet your 1,500 goal!
Cliffmeister2000 wrote:Test fitting the door is definitely an exciting point in the build! Looks good!!
