Shadow Catcher wrote:The timing belt etc may be covered by warranty as it is part of the emissions system, (used to be any way), depending on what is found I would be A) checking the warranty information and B) talking with Subaru of America, and remember they do not want to pay for it so you have to know what your rights are, and hold their feet to the fire!
The belt is supposed to last 115,000 miles.
emiller wrote:Shadow Catcher wrote:The timing belt etc may be covered by warranty as it is part of the emissions system, (used to be any way), depending on what is found I would be A) checking the warranty information and B) talking with Subaru of America, and remember they do not want to pay for it so you have to know what your rights are, and hold their feet to the fire!
Most belts are recommended to be changed at 60,000 miles. And are not covered under warranties.
Miriam C. wrote:Um shouldn't the computer have told the mech. if it was a timing issue. I mean .........
My truck stalled again even after I got it tuned. Just stalled out and the check engine light came on but it started back up.
emiller wrote:Wow your right. 105,000 miles replacement. But it also says in my maintenance manual that the belt should be inspected at 30,000- 60,000 and at 90,000 miles.
WarPony wrote:Miriam C. wrote:Um shouldn't the computer have told the mech. if it was a timing issue. I mean .........
Ah, alot of people have the misconception that the "computer" will tell you EXACTLY what's wrong with the vehicle. A diagnostic scanner is mearly a "tool" for the mechanic, he/she can use the DTC's (diagnostic trouble codes) to help figure out what the problem may be but they aren't a tell all. Most but not all DTC's are caused by something other than what the ECM (engine control module) has detected
Miriam, as far as your truck stalling after you got if fixed......... bad mechanics-manship. A good test drive should've revealed the problem.
Jeff
