Doors - Custom or Prefab
Postby TheBizMan » Sun Aug 15, 2010 5:53 pm
Did you build your own doors or did you buy prefab ones? If you bought prefab, where did you get them?
Lee - TheBizMan sez
Teardrops make for happy camping
TheBizMan
Postby Cliffmeister2000 » Mon Aug 16, 2010 8:39 am
Built mine.
God Bless
Cliff
♥God. ♥People.
1 John 4:9-11
My Teardrop build pictures
Cliffmeister2000
Titanium Donating Member
Images: 157
Postby planovet » Mon Aug 16, 2010 9:37 am
Built mine also. It was a PITA but it was worth it. Prefab doors would not have looked as good.
ImageMark (& Cindi)
planovet
The Cat Man
Postby caseydog » Mon Aug 16, 2010 10:36 am
I bought mine on eBay. They are the same doors that LittleGuy uses. Do a search on eBay for "teardrop doors," and you will find at least one seller.
CD
My build journal is HERE
caseydog
Images: 515
Postby dh » Mon Aug 16, 2010 8:30 pm
I did the same as CD, but I got lucky, found a SET for $300
dh
Postby 7Grand » Wed May 25, 2011 2:39 pm
Prefab doors are available at www.bigwoodycampers.com. You can also find a kit there for everything needed for traditional doors.
7Grand
Postby MKE_Tear » Fri May 27, 2011 5:28 am
Bought mine prefab (from Vintek1958 on eBay).
For me it bought peace of mind, and a relatively "easy" installation.
I wasn't sure of my own personal construction skills/knowledge to make something that would function properly (not to mention air & water-tight)...coupling that with the cost of acquiring two sets of windows, latches, locks, handles, hinges, weatherstripping and anything else I left out, and it was the safer way for me.
Certainly a big bite in the wallet all at once...but the time involved to research how to do it and then construct it (again, for me), while adding up the cost of acquiring all the parts, and it was my best route. (Note: "my" best route.)
All the best!
MKE_Tear
Images: 243
Postby aggie79 » Fri May 27, 2011 8:22 am
Building the doors was perhaps the biggest PITA in my build, many times more trouble than building the hatch, but I was going for a certain look.
If the pre-made look works for you, you will be time and money ahead over making the doors when you consider what plywood/framing, windows, hinges, latches, t-molding, weatherstripping, etc. cost.
