The flush cutting bit worked very well:
I've done next to nothing with a router (before this project) and yet I have been very pleased with my results (from stretching the plywood to trimming the sheeting).
I identified additional progress in that I had to dump my 8 gallon shop vac. I've already filled it with sawdust. When using the flush cutting bit it seemed like I was not just making it snow but that I was in the middle of a blizzard.
I read somewhere that someone said it is more difficult to make a trailer/camper with angles (like the Grasshopper style) than the more typical teardrop design which requires bending the plywood. Well, I'm starting to think there is some serious truth to that statement.
For skinning MY grasshopper, it appears that each section (or angle) takes one full day: measuring the size of the plywood, cutting it, getting the angle(s) right so it matches up with the previous sheet and then the next sheet, priming the inside (min. 2 coats) and letting it dry, glueing/screwing, using the flush cutting bit on the overhang, wood filler on the the now "flushly cut" areas, and lastly, measure, cut & glue the insulation. And it could be even longer if you have a window or vent hole to cut out.
(Now I realize I could deal with the insulation later, doing the entire inside at once (like an efficient assembly line), instead of setting up the sawhorses and laying out the insulation each time (but that's only a five minute deal) but I like knowing that all I have remaining to do is skin/sandwich board the inside.)
So, now that I've got my second (skinning/sheeting) section done...
...it looks like it will take me two more days to do the two remaining roof sections. I can't wait to get done bec. I want to get to sealing it up with the aluthane. I've decided to seal it (the bulk of the camper) before I work on the hatch. Anyways, even before sealing (and after skinning), I have plenty to do: build & insulate the dividing wall, panel the inside, and finish the front. Gotz a lot to do!
My next section should be fun -- I have to cut out the hole for the vent.
