A Friends box trailer build of a hunting / camping trailer
Postby ARKPAT » Sat Sep 04, 2010 4:29 pm
Here are a few pictures of my friends ( now register here as crod ~ Charlie ) first trailer build of a box camping / hunting trailer. Very simple box shape....note extended tongue. The frame is an older 1820# HF modified tongue ( thanks Nobody (Harvey & Lenora) Teardrop for the design ).
Yep there will be a tongue box.
Pat
Life is to short always eat dessert first.
ARKPAT
Images: 77
Postby MKE_Tear » Sun Sep 05, 2010 9:19 am
Good luck, Pat! Keep us updated, when you can. All the best!
MKE_Tear
Images: 243
Postby ktnc30 » Sun Sep 05, 2010 4:20 pm
That is a tall one. Seems it would be top heavy once done since it looks narrow?
ktnc30
Images: 93
build
Postby Wild Bill » Mon Sep 06, 2010 8:55 pm
If that is steel u channel it will be very heavy when done. The Axle may not be heavy enough to hold it all. Bill
Beavers are Naughty!
Wild Bill
Images: 63
Postby LDK » Tue Sep 07, 2010 6:21 am
I sure would like to see this trailer when it's done. :coffee:
LDK
Postby ARKPAT » Tue Sep 07, 2010 9:15 am
It is 6 foot high. I did mention about the height problems he might have with side winds on the road but; I have talked about making it 6 foot wide and maybe add a longer axle under to make it under 80" wide overall. Yep; it is steel "C" purlins for the structure and base angle upper and lower edges. It is on a older 1850# HF frame. It is surprising lighter than I would have envisioned. I would have liken to have the "Thrmo-Tru" insulated doors for wall construction like my trailer ( an easy after thought that could be changed later ).It could real easily be turned on edge and remounted on its side. It is REALLY STRONG! You could just add a tongue, springs,axle and wheels as it is without the HF frame. 8)
Charlie ( Check under "crod" member ) has made it a family project and his first build ;)
You need to put your tag on it and take it down the road. I will see him later today and maybe get him to drive it around to get the feel of it.
Funny the frame has over 20,000 miles on it. ;) :lol:
:D :P :pictures: :campfire: :relaxing: :icedtea: :picklejuice: :designing: :beautiful: :cheerswine:
:applause:
Pat
PS: My trailer has made some changes in it also; but will look the almost the same for LCG this year. I know pictures follow later :) 8)
ARKPAT
Images: 77
