Door Hinge Question
Door Hinge Question
Postby LDK » Wed Sep 08, 2010 6:13 am
What kind of door hinge should I use for a door that will be 1&1/2" thick? My door and walls will be a sandwich construction. 1/2" ply, 3/4" insulation, and 1/4" interior skin.
Larry
LDK
Postby aggie79 » Wed Sep 08, 2010 8:20 am
My doors are 1 1/4" thick and are similar contruction to your doors. I purchased my hinges from McMaster-Carr. They are part #1264A12.
Two per side are sufficient for each door. I went with three per side because I thought it looked better.
Postby planovet » Wed Sep 08, 2010 8:28 am
I used torpedo hinges for mine. I like that I can lift off the door if I ever need to.
Two would have been sufficient but I thought three looked better too. I guess Aggies think alike. :lol:
ImageMark (& Cindi)
planovet
The Cat Man
Postby schaney » Wed Sep 08, 2010 1:07 pm
If you like the Strap Style hinges, we use them on our Explorer Boxes and offer them for 1/2 the price of McMaster
Scott
Camping the "Compact Way"
schaney
Images: 262
Postby Sam I am » Wed Sep 08, 2010 9:15 pm
I used the same hinges that Schaney used. They are strong and cost me about $5.00 each in 2006.
Sam I am
Images: 106
Postby LDK » Wed Sep 08, 2010 10:44 pm
With the strap style hinge whats the best way to fasten it. With a bolt and nut, t-nut or wood screw??? :thinking:
LDK
Postby schaney » Thu Sep 09, 2010 8:51 am
LDK, for a heavier door like on a teardrop I'd go with bolts & nuts or bolts into t-nuts. On lighter doors like an Explorer Box front or side compartment, wood screws work fine, but if it will see off-pavement towing I like to go with bolts & nuts.
Scott
schaney
Images: 262
Postby H-Balm » Sun Sep 19, 2010 5:12 am
planovet wrote:I used torpedo hinges for mine. I like that I can lift off the door if I ever need to.
I LIKE that look!
Are those tricky to locate?
(vendor, vendor, eh, eh?)
So you open the door... get a good hold.... and can lift it off?
That seems like a really handy thing when loading.
H-Balm
Postby planovet » Mon Sep 20, 2010 8:31 am
Yep, easy to lift off once the door is open.
Right hand hinge
Left Hand hinge
ImageMark (& Cindi)
planovet
The Cat Man
Postby H-Balm » Sun Sep 26, 2010 5:01 pm
planovet wrote:Yep, easy to lift off once the door is open.
Right hand hinge
Left Hand hinge
So when you open the door?
How Far does it go back?
Does it lay close to flat?
H-Balm
Postby zapj » Sun Sep 26, 2010 7:19 pm
I use the bullet hinge as well but decided only two per door. Great hinge and yes it will allow the door to swing all the way open. Ask me how I know as I had a door knob imprinted on the side wall. I was just thankful the window wasn't open. The removable feature was great during construction because the door could be constantly removed for fitting and finishing without having to remove and replace screws constantly. Some people I knew voiced concerns about not having hidden screws and how that may encourage thieves. If that is a concern just mix some epoxy and place in the screw heads.
zapj
Images: 40
Postby planovet » Mon Sep 27, 2010 8:49 am
Yep, it will go all the way flush to the side. Like zapj said you have to be careful or your open window or handle will hit the side.
ImageMark (& Cindi)
planovet
The Cat Man
Postby H-Balm » Tue Sep 28, 2010 3:46 am
Thanks for the replies, zap and plano!
They do sound great (opening allowing more space to move at your site; and removing during construction).
I just got the price estimate..... staggering!
Wasn't expecting that!
Need to think... and research!
H-Balm
Postby zapj » Tue Sep 28, 2010 3:43 pm
I purchased mine from Moore Industrial Hardware on the internet. Type in the search box at their site, Torpedo hinge and your choices will show. Be sure and purchase both left hand and right hand hinges. I paid approx $79 back in '09 for my four. The site lists 'call' for a quote.
zapj
Images: 40
