1.Sandblast or grind down? Pros/cons of each?
2.What type of paint to use? Por-15?
3.New axle and if so where to buy? New hubs?
4.Keep the brakes or remove them.
5. Upgrade from 12 inch to larger wheels?
jon p wrote:I picked up a used frame today for $100 bucks. I want to make the deck of my teardrop 6ftx10ft and was happy that this frame is exactly that. My plan is to cut off the old bumper mounts, either grind it down or have it sandblasted, and paint it. My dad is a master welder and I will also have him inspect the frame and weld some spots that looks to be separating where the frame joins in places. The guy was honest with me and told me he thinks the frame has been overloaded. The wheel are toed in and the axle is arcing. I have a list of questions I was hoping you all could help me out with and give me advice.
bobhenry wrote: Were it mine I would very lightly sand or wire brush the frame simply to knock off scale and road grime and apply 3-4 rattle cans of automotive undercoating to the frame saving you hours and hours of hard work.
