mikeschn wrote:My signature line?
Makes sense to me!!!
greekspeedoman wrote:I used Interlux products. It was easy to use, self leveling, and easy to apply. Prices are around $30 / pint. I used most of 4 pints for my 5'x10' (3 coats over it all). It has teflon in it and everything falls off of it. I applied it over two coats of Interlux primer ($20 / gal) and 4 layers of fiberglass epoxy.
It is made for boats. UV stable and I've had no problems in 4 years. It also comes in a bunch of colors.
read more here: http://www.overlandtrailer.com/body-external
Riken wrote:this paint is thick and syrupy and strong but wow . This is the first coat over my primed surface. you can see the REFLECTION of the ac in it. this was after its dry. this paint is sticky immediately after applied and dries to touch before you know it
here are the recommend uses:
For use over prepared substrates such as steel, galvanizing, and
concrete in industrial environments.
• Laboratories
• Lavatories
• Masonry surfaces
• Power plants
• Offshore structures
• Schools
• Storage tanks
• Marine applications
• Structural & support steel
• Clean rooms
• Institutional kitchens
• Nuclear Power Plants
• DOE Nuclear Fuel Facilities • Nuclear fabrication shops
• DOE Nuclear Weapons Facilities
• Chemical processing equipment
• Institutional & commercial wall coating
• Suitable for use in USDA inspected facilities
• Conforms to AWWA D 102, OCS #5
• Acceptable for use in high performance architectural applications.
• Conforms with MPI # 77
• This product meets specific design requirements for non-safety
related nuclear plant applications in Level II, III and Balance ofPlant, and DOE nuclear facilities*.
* Nuclear qualifications are NRC license specific to the facility.
I would say you can wedge camper, ttt or teardrop somewhere in that mixi was totally impressed either that or was inundated with the fumes
