Miriam C. wrote:Actually if you leave that forward cabinet you will crack your head a few times
Weirdnerd wrote:Hi RockyMountainTeardrops,
Weirdnerd wrote:I used to build carbon fiber aircraft...... and knowing the difference between 0/45/90 degrees on the layup will save your sanity
Weirdnerd wrote:keep in mind that the vacuum systems are not cheap ( pump, harbor freight is about 90 bucks, and the fittings for the vacuum bagging/ vacuum hose will run you about 150 bucks or more) it.
Weirdnerd wrote:You can build the walls, with a 1/8 thick plywood lay them flat, ( make sure they are VERY flat) and add a ply at a time, one trick is to wet (resin) the fiberglass over a sheet of clean plastic marked with a sharpie with the shape of what you want to cover ( like the plastic drop cloths they use for painting), cut to size (with the wet resin the fiberglass over it) then use the plastic to locate the fiberglass over the structure, then squeege it very well ( to remove bubbles and excess resin), remove the plastic carefully and leave the fiberglass in, repeat for the other two plies.
Once the three plies are in place, you can cover them with release peel ply, perforated ( it's like a plastic film, with holes to bleed the excess resin) and squeege it firmly, making sure you don't have voids, excess resin, or "pleats" , the plastic release film serves two purposes, one, to keep dust and debris from becoming part of the finish, and two, keeps the lay up in place and makes a smooth ( shiny) finish.
the perfect way to lay them is 45/0/45 ( orientation of the fibre strands) so you have a flat finish ( some other combinations create waves, or warping on the laminate, so this is the easiest way to make sure it is flat).
Once the resin has cured ( I would recommend a slow cure catalyst, so you have lots of time to correct misplacements and not worry about it " gelling on you", you can remove the peel ply release film.
when you want to lay up an overlapping laminate ( say, the roof to meet the sides, which create a solid shell) make sure you sand the cured laminate ( over which you will lay up the fresh resin fiberglass) with crocus cloth 80 grit or 120 grit ( avoid aluminum oxide, it will turn into sulfate due to galvanic corrosion, and it will delaminate the fiberglass) 1/2 an inch past the edge of the new plies, , clean very very well with methyl alcohol and a lint free paper towel, wait 15 minutes ( no more than 2 hours) and proceed to lay up,
a good way to lay up the overlapping plies ( the roof, that will overlap the sides) is to make the first one 3/4 of an inch smaller than the second and the second 3/4 of an inch smaller than the third, that way you will not have a " lip" thicker than the rest of the laminate...it's kind of hard to explain in writing, but I am sure I can explain any other questions better.
PS, a better location for the vacuum port ( the one inside the bag) is to make a small extension for the bleeder material about 2 to 4 inches away from the laminate, so the vacuum port doesn't suck resin, and you don't end up with permanent port marks over the fiberglass.
RockyMountainTeardrops wrote:I'm sure I'm killin' you all with this many pictures for one post.![]()
Lee
Weirdnerd wrote:You,, have a garage to work in...I had to rely on good weather last winter to build mine:lol:
asianflava wrote:Nice rig! I lived in NC for 4 years and TX for 10, I know what BBQ is supposed to taste like and I had a hard time finding it in CO. I had to learn how to do it myself. Been using a BGE with a DigiQ, with good results. Just pulled a brisket off 30min ago.
