Keep up the good work
http://www.radiantz.com/cart/index1.html?c17.html&1
vtx1029 wrote:The only thing bad about them DEI lights is it sucks when you need to change a plate having to cut the wires.
ME87 wrote:I plan on lighting the trailer using two modified 3D Maglites. I've put P7 LED's in them and they're about as bright as the sun so they should provide enough light to do anything I want and in addition, they will be mounted on quick connect mounts so they are portable when it gets dark.
