ME 87's Truck Bed Thread
Postby vtx1029 » Tue Nov 16, 2010 2:21 am
The only thing bad about them DEI lights is it sucks when you need to change a plate having to cut the wires. Check out the lighted plate frames below. Much nicer and super bright!
Keep up the good work :thumbsup:
http://www.radiantz.com/cart/index1.html?c17.html&1
vtx1029
Images: 70
Postby ME87 » Tue Nov 16, 2010 3:10 pm
vtx1029 wrote:The only thing bad about them DEI lights is it sucks when you need to change a plate having to cut the wires.
One of my favorite tools in the garage
http://www.howardelectronics.com/weller/wes51.html
My wires almost splice themselves :lol: but that is a nice frame
ME87
Postby vtx1029 » Wed Nov 17, 2010 12:01 am
Another thing you could do is call the people I sent a link to. They have much more then what's shown. I believe they had just like a chrome eyebrow with several LED's in it that you could mount above the plate. They are a cool blue tint so they look really trick.
I helped design this sidemount/ and plate frame that my friend manufactures. They use side firing led's that are recessed into the top of the plate frame and are only 1/8 inch thick 8)
None the less soldering is easy too :lol:
vtx1029
Images: 70
Postby ME87 » Wed Nov 17, 2010 12:05 am
Got the mounts for the Spare tire crossmember drawn up. Off to the laser in a day or two. I put the tire under the bed in front of the axle with hopes to get the tongue weight up a little.
ME87
Postby ME87 » Wed Nov 17, 2010 10:21 pm
Mudflap Mounts to match my truck
ME87
Postby ME87 » Wed Nov 17, 2010 10:50 pm
I plan on lighting the trailer using two modified 3D Maglites. I've put P7 LED's in them and they're about as bright as the sun so they should provide enough light to do anything I want and in addition, they will be mounted on quick connect mounts so they are portable when it gets dark.
ME87
Postby vtx1029 » Thu Nov 18, 2010 12:12 am
ME87 wrote:I plan on lighting the trailer using two modified 3D Maglites. I've put P7 LED's in them and they're about as bright as the sun so they should provide enough light to do anything I want and in addition, they will be mounted on quick connect mounts so they are portable when it gets dark.
you make your own or is there a drop in now?
vtx1029
Images: 70
Postby ME87 » Thu Nov 18, 2010 10:00 am
I made my own.
ME87
Postby ME87 » Fri Nov 19, 2010 10:28 pm
Got the license plate box made today as well as the spare tire crossmember mounts and mudflap parts. I should be able to get that all installed tomorrow so updates to come. My heater project is still making progress as well.
As per the request of the mods, all images have been re-sized for reasons I'm still unclear on, but w/e.
ME87
Postby ME87 » Sat Nov 20, 2010 9:39 pm
Got the license plate box done
Got the spare tire carrier done
and I figured out a good use for some pneumatics. Just put an air ratchet on the extension that is permanently in place and I can easily raise and lower the tire.
Safety Chains
Mudflaps.
I should be able to get the wiring for the lights completed tomorrow and then I'll go get it registered sometime this week now that I can pass inspection.
ME87
Postby ME87 » Sun Nov 21, 2010 1:21 am
So I added up my budget thus far and I'm right around 800$ including the brand new axle, all raw materials, and the bed. I think for right around 1000$ I'll have it covered and ready to sleep in.
However I did take a quick tally on the cost of tools and it's a bit higher
Laser 800K
CNC Press break 300K
CAD software 10K
Garage full of every tool known to man 100K
Something's not right here lol
ME87
Postby ME87 » Tue Nov 23, 2010 9:49 pm
Got the wiring and lights installed
A shot of where I had to shorten the axle and where the spare sits. This is looking forward from the back
I got the roof spars designed
They will be laser cut 1/8" plate with some 1X1 tube in between so I can rivet 0.030" AL skin to it. I wanted solid walls, but not the look so the entire AL skin will be covered with canvas. The large window area on the right is actually for part of a slideout box. This will be where my feet rest when in bed.
ME87
Postby ME87 » Sun Dec 26, 2010 7:47 pm
Haven't had a lot of time to get much done recent, but I did get it titled and registered and I did manage to get the roof subframe structure done this weekend.
This is what a rough side view will look like, as it will be skinned in .03 5052 AL, but will then be covered in a similar canvas to this for a more natural look.
ME87
Postby ME87 » Tue Dec 28, 2010 12:11 am
Got 3 of the skins drawn up tonight. A couple more to go and then lots of riveting and seam sealer I guess.
ME87
Postby ME87 » Wed Dec 29, 2010 12:16 am
Finished up the outer skin layouts. Just need to cut them now.
Also started the geometry for the slideout. Should be good for 2 people side by side under 6 feet tall.
ME87
