Thinking about #2...a caboose?
Postby planovet » Fri Nov 19, 2010 11:10 am
The "box in a box" idea was what I was going for. I was thinking about lipped edges that would prevent water intrusion when closed. Mine will be above the kitchen, not above a shower so I do not want ANY water getting through.
The windows could be problematic though.
ImageMark (& Cindi)
planovet
The Cat Man
Postby GPW » Fri Nov 19, 2010 11:26 am
Lipped edges !!! Oh Yeah !!! Cool !!! 8)
Kitchen ??? Stand up kitchen... ??? Hmmm... about 4'X4' ... that's pretty good size eh ? Power vent on top would act as an exhaust fan !!! :thumbsup:
Postby oicu812 » Fri Nov 19, 2010 2:09 pm
How about a pneumatic seal on your slider made out of bike inter-tube.
Glue a couple together and put in a slot, make so you have a little clearance to slide. When in the up position pump it up, when down the overhang seals it.
Pie are square?
oicu812
Postby planovet » Fri Nov 19, 2010 3:20 pm
oicu812 wrote:How about a pneumatic seal on your slider made out of bike inter-tube.
(in my best Arte Johnson voice) Verrry interrresting! :thinking:
ImageMark (& Cindi)
planovet
The Cat Man
Postby myoung » Fri Nov 19, 2010 7:01 pm
You could also add weatherstripping on the top surface of the roof lip so that it compresses once the cupola is lowered. Some rubber or other seal fastened to the lip should do the trick.
Mike Young
myoung
Images: 250
Postby Ageless » Fri Nov 19, 2010 8:02 pm
Another idea: build the pop-up with a slight taper. Then when raised it will compress the seal.
Ageless
Postby GPW » Sat Nov 20, 2010 7:10 am
Ageless, you give us too much credit ... hard enough to build a straight box ... :o But it is a cool idea ... 8)
Postby planovet » Sat Nov 20, 2010 11:45 am
Interesting combo
A caboose styled trash receptacle.
Hot Dog Caboose
Fireplace in a renovated caboose. I have a little (2' high) stove like that that would look great in a caboose trailer if I could make it fit. (non functioning, just show)
ImageMark (& Cindi)
planovet
The Cat Man
Postby GPW » Sat Nov 20, 2010 1:32 pm
Whoa !!! NICE caboose pics !!!! Makes me wish I had a Real one .... 8)
Postby myoung » Sat Nov 20, 2010 4:29 pm
Thinking about cabooses, I am reminded of a famous restaurant and bar in Dryden, NY, called "The Boxcar." It was founded by Garry Morfit in about 1965. He is the son of Garry Moore, the TV entertainer.
In those days, we had many interesting watering holes and eateries in and around Ithaca.
:beer:
The idea was appropriated by other Cornell Hotel School alums and became the successful Victoria Station chain (now gone, alas).
Mike Young
myoung
Images: 250
Postby vairman » Sat Nov 20, 2010 9:22 pm
Are you going to have a rounded roof or a flat roof? The rounded roof would be easer to seal than a flat roof, also you could utilize screw jacks off a popup to raise and lower the roof. Let me think about a leak proof seal when it is raised...
Greg :)
vairman
Images: 215
Postby planovet » Sun Nov 21, 2010 9:29 pm
I was thinking more of a ronded roof. The part (or box) that the cupola would slide down onto would be flat.
ImageMark (& Cindi)
planovet
The Cat Man
