Sparksalot wrote:Rose is 5 wide, and uses 6 ribs. The outer two are doubled.
Toytaco2 wrote:Well, yes, I did insulate my hatch and finally found a pic to prove it. Seems to me if the rest of the build is insulated, then the hatch ought to be insulated also.
stupido wrote:Well, do not have a tear drop yet and I have not even used my bed tent camper for my truck yet. But I do like rum. Here is my favorite:
If I mix it, it is mixed with ice. Unfortunately it is hard to find and my supply has dried up
Sam I am wrote:I went a simpler way on my hatch. I built the rear of the teardrop with spars and skin as if there wasn't going to be a hatch, then cut the hatch free after it was skinned. The advantages: no curved ribs to make, and only two curved jigsaw cuts to make. It's light, simple, and has zero spring back with 1/8" Baltic birch skin. The birch literally falls around the curve, and produces no forces trying to make it spring back. I added a second layer of 1/8" skin on the teardrop and the hatch for more strength. There are more photos in my Flickr album.
cuyeda wrote:I hope you don't mind me asking this question in your thread. After seeing all the hatch builds. I didn't see any insulation addition in any of the pictures. Is the insulation not needed in the galley areas?
