DD, on the road to LCG
Postby aggie79 » Fri Dec 10, 2010 11:50 am
Gary,
That is some galley you have there! I like the use of the laminate flooring. I can't wait to see you and the Diner at Beavers Bend.
Take care,
Postby jkidd6339 » Fri Dec 10, 2010 9:07 pm
Gary
The galley looks great. I think the Vynil on the counter is a great idea. It will be much more functional than mine. I guess mine will be mostly for cargo. When do you figure you will try it out? How's that thing with Ronda working out?
jkidd6339
Postby StPatron » Fri Dec 10, 2010 10:14 pm
jkidd6339 wrote:Gary
Thanks jkidd. It resembles vinyl but is actually Shaw brand laminate flooring that I found at Habitat, heckuva bargain but only 6 panels. I sealed the edges with Titebond III, hope it holds up. It's sturdy, I laid down on it for testing. I'm shooting for a March completion but it's looking iffy.
Haven't heard from Rhon in months. I was the best man at her wedding at Stanton Creek in September. Pete officiated at the ceremony, supplying kazoo music. Missed seeing you at the rally.
StPatron
Images: 297
Postby High Desert » Sat Dec 11, 2010 12:30 am
Gary, great call on the laminate for the counter. Looks sharp! I made a small table some time back and used some leftover laminate flooring for the top. Works great and tough as nails. And on that monster counter the tile look is awesome. :thumbsup:
Shaun
High Desert
Images: 27
Postby Lookfar » Sat Dec 11, 2010 12:43 am
Gary;
I've been enjoying your build for a while. The problem is, I keep bouncing back and forth between pages, and forget to comment on anything.
You've got an interesting trailer going. Hope to see it at Beavers Bend.
Butch
Lookfar
Images: 22
Postby StPatron » Tue Dec 14, 2010 10:17 pm
Thanks Shaun and Butch!
Today was absolutely gorgeous and I enjoyed a ride in the country on my 78 Harley Davidson Sportster. It's a 75th anniversary edition model that I restored,,, complete basket case. Got a lot of thumbs up from folks who enjoyed seeing an older HD on the road.
Then, it was back to work on DD.
This is the burner I'm using. Originally intended for use as a side burner on a full-size grill.
I used full extension slides for mounting. This allows the lid to flip up once the burner is fully extended. I mounted the slides directly to the unit, no worries of catching a support tray on fire. No wobble when extended, it's very sturdy with the 100 lb. rated slides. Allowance was made for the propane cannister to fit without contacting the a/c plenum. Part of the fiberglassed drip pan for the a/c can be seen.
Lid open
Simmer
Full blast
I think I'll really enjoy this, it's so simple to use. Pull out the unit, lift the lid, rotate the knob,, that's it. Auto-ignition. I believe it's rated at 10,500 btu's, should work great! Later, I may route black pipe from a tongue-mounted 20 lb. tank. For now, this will work.
StPatron
Images: 297
Postby Cliffmeister2000 » Wed Dec 15, 2010 12:06 am
That's really nice, Gary! :thumbsup:
I'm guessing you chose slides with a 100 lb rating. I'm curious how stable it is with a big pot of boiling water on it?!? :thinking:
God Bless
Cliff
♥God. ♥People.
1 John 4:9-11
My Teardrop build pictures
Cliffmeister2000
Titanium Donating Member
Images: 157
Postby StPatron » Wed Dec 15, 2010 1:58 am
Cliffmeister2000 wrote:That's really nice, Gary! :thumbsup:
Thanks, Cliff.
Yes, those are the 100 lb slides. I tested it in the full extension position and it's not going anywhere. No slop in the tracks and no downward tilt. I'm using the same slides for my cooler and am very pleased with both applications.
If a big pot of boiling water goes down,, the tongue will be pointed skywards. :lol:
StPatron
Images: 297
Postby aggie79 » Wed Dec 15, 2010 10:00 am
Gary,
That burner is really cool! Could you say what the rough dimensions of it are?
Thanks, Tom
Postby StPatron » Wed Dec 15, 2010 9:32 pm
aggie79 wrote:Gary,
Thanks, Tom
Here ya go, Tom.
13-1/2" wide, 16-1/4" deep, 4-1/2" high. That height is the burner unit alone without the disp. propane cannister installed.
The top actually has a nice finish, I forgot to clean up the sawdust before snapping the pic. The corners on the left side are radiused, the corners on the right are squared,,,, it's designed to attach to the left side of a grill. I had concerns about insetting it into the countertop (clearance/fire and cannister access) and therefore decided to go with the slide mount.
StPatron
Images: 297
Postby aggie79 » Thu Dec 16, 2010 9:14 am
Thanks Gary.
This info will help me try to figure out my galley layout. I'm kind of stumped right now in trying to fit everything I think I need. The compact size of this burner may allow me to store my cooler in the galley.
Take care, Tom
Postby StPatron » Sun Dec 19, 2010 2:49 am
Cold in the shop today, so the back-up plan was to work inside sewing the dinette cushion covers. I selected a medium-high density 4" foam and had the supplier cut the pieces to size. That worked great, no ragged edges. I did one last check of the fit and was pleased. I think the 4" thickness will provide me with the desired combination of both comfort and table clearance for my legs when seated.
Dewey enjoyed helping with the paper pattern cutting.
I've done a bit of sewing but never attempted major upholstery work, so I spent some time last week researching online. I like the challenge of learning something new. I decided on a box cushion style without piping and began cutting out the material, then sewing. Dew quickly lost interest, hopped up on his perch and snoozed while I worked.
This is back cushion #1. I still need to add the zipper panel and detail the corners but I was anxious to see how it fit and looked. Almost one down, three more to go.
StPatron
Images: 297
Postby grizz » Sun Dec 19, 2010 9:06 am
Nice pics Gary, Dewey looks like the perfect helper.
Our 3 cats have become incredibly "homely" since we got married and moved into one house.
Harley sleeps on the foot end of our bed, between Nicola and I
Dukey (Marmaduke) sleeps in the Radiator hammock bed at the window. He sneaks into the garage when the door is open and crawls intot he teardrop for a sleep, have locked him in there before by accident.
Tabitha the old girl sleeps in my office in my box of tools..... on top of the drill and other stuff, and no I do not know why she does.
She also takes duty when you shower as "life saver cat"
Nicola just came in to show me a scratch from Dukey, he is high on American Catnip ..... it drives him mad.
Greetings from England.
Rian.
grizz
Images: 29
Postby S. Heisley » Sun Dec 19, 2010 11:31 am
It looks like you're doing a good job on those cushions, Gary. I hope mine turn out as good! :thumbsup:
Postby StPatron » Mon Dec 20, 2010 12:42 am
Rian: Good to see you posting again, thanks for checking in. Sounds as if your cats have adjusted well to the move, they all have such different personalities. I planted a patch of catnip on my acreage and it's quite popular. Have you been doing any camping lately?
Sharon: I know your cushions will turn out fabulous, just like the rest of your camper! There are so many nice fabrics to chose from, I saw a tapestry on eBay that was to die for,,, but, it wasn't in the budget. The "plain Jane" remnant piece I used wasn't large enough to cover all the cushions so I pieced in a different material on the backs/bottoms. Keeping the two different materials aligned properly was tough but worked out ok. I finished the other back section today and started working on the seats, I'll post pics of all the cushions when they are completed.
I didn't realize there were so many foam options. 4" seems to be the standard thickness, then there are varieties of density and compression. The salesman had samples and he would put them on a chair for me to test. It became rather amusing. :lol:
You may find this tutorial on box cushion sewing helpful:
http://www.alternative-windows.com/box-cushion.htm
StPatron
Images: 297
