Mike Young said:
"I'm curious about your choice of fasteners, a combination of adhesive and self-tapping screws. In my research on the forum for methods of attaching the body to the frame, it appears that most use just a few bolts.
I don't recall seeing any mention of adhesive between the body and the frame, presumably because there might be a need to separate the two at some future date.
Was your decision based on the contours of the floor and the possible difficulty attaching all the pieces to one another?"
My response:
The screws & adhesive/sealant were used just to attach the plywood floor to the frame. The bottom plate (body) will be attached to the frame, through the plywood, with 1/4" x 2" self tapping cap screws. The adhesive/sealant also, was used to seal the screw holes, (in the plywood) from moisture. There will not be a separation of the plywood from the frame in the future. I do not see a need. I used more than 250 screw to attach the plywood. I have 100 1/4" screws to attach the bottom plate to the frame through the plywood floor. A photo of the #10 x 1" screw is on the left. The 1/4" x 2" screw is on the right
![Image](http://i286.photobucket.com/albums/ll89/terryjones3/Terrys%20TTT%20build/IMG_0492.jpg)
