parts for model 500 a one burner
Re: parts for model 500 a one burner
Postby rainjer » Sun Dec 26, 2010 9:13 pm
slowcowboy wrote:
I have a one burner 500 a stove and am in need of a new tank dip stick vale part.
Slowcowboy.
I have no idea what you are talking about. Do you have a picture?
Jeremy
rainjer
King Koleman
Images: 11
Postby doug hodder » Sun Dec 26, 2010 9:26 pm
I think you are asking for an air stem. If it's the part that goes in the pump and allows you to close the valve after you pump it up. Are you missing just the stem or in need of the check valve and stem? They are usually sold in a combo of valve and stem. If it's just a stem you need and your check valve...(in the bottom of the pump) is OK...I've got one that you can have, it's the older version that that stove would originally have had, larger threaded end on it...The newer versions only work with a new check valve and has a smaller needle on it. Most any of them for lanterns should fit this stove 4.5" tip to end. If you have any older lanterns that are parts lanterns, rob one. Doug
Postby doug hodder » Mon Dec 27, 2010 9:50 am
Sorry I don't have any of those parts. I don't think anyone knows the production numbers on these stoves, but they aren't as plentiful as the suitcase type stoves. However they aren't that tough to come by, lots of us here have them. Bob Hitchcock the Coleman guy up in Washington may have the part you need. I think his site is down between Christmas and New Years though. Doug
Postby parnold » Mon Dec 27, 2010 1:01 pm
Slowcowboy.. here's a link to a pdf of an old parts catalog. It covers the model 500 so you can see what part number you need. It may make it easier to find.
http://www.pressure-lanterns-il.com/tech-n-info/Coleman_technical/OldDirtyColemanPaper/1955ColemanPartsCatalogNo32A.pdf
parnold
Images: 302
